new pinephone received with no battery?
I finally got my new 3gb pinephone.
Plugged it into power, installed postmarketos.
Wifi through phosh doesn't seem to be doing anything.
I popped off the back, and there's no battery.
I'm not supposed to have ordered a battery separately, right?
(09-02-2020, 01:10 PM)senorsmile Wrote: I finally got my new 3gb pinephone.
Nope, there should be a battery supplied. I know they had issues sending "naked batteries" (batteries by themselves), but that shouldn't affect you. It wasn't hidden somewhere in the box was it? If you're desperate, go here: https://wiki.pine64.org/index.php?title=...ne#Battery and source one locally that will fit. And obviously contact the sales support team.
I took pictures of the unboxing, so I had a nice clean area.  I double checked the box, shipping box, inside.  There was a piece of tape where I think it should have been, but just sitting there.  The battery bay is definitely empty.. I can see the contacts where it would connect.
I emailed support.
I believe this is why wifi probably won't work for me ... not enough power to supply the radio.
(09-02-2020, 04:39 PM)senorsmile Wrote: I believe this is why wifi probably won't work for me ... not enough power to supply the radio.
In another thread it was mentioned that wifi doesn't work if there is no battery.
The samsung J7 2015 battery is the battery in the pinephone. You can probably find one locally, and certainly online.
  Pinephone boot. Richy_T 4 89 Yesterday, 08:32 AM
Last Post: Richy_T
  PinePhone - boot from microSD laserpyramid 9 849 05-03-2024, 10:09 AM
Last Post: laserpyramid
  pinephone virtual keyboard aular 4 425 04-10-2024, 03:45 PM
Last Post: aular
  PinePhone Doesn't Boot LED Doesn't Show Any Signs When Charging dorkydev 1 289 04-02-2024, 11:50 AM
  Are you using the Pinephone as your daily driver? jro 157 110,768 02-18-2024, 11:33 PM
Last Post: aular
  2020 PinePhone Manjaro CE EU for sale, name your price astrojuanlu 7 1,925 02-14-2024, 04:51 PM
Last Post: astrojuanlu
  pinephone is not bootble for the box. ijij 1 666 01-19-2024, 01:29 PM
Last Post: fxc
  Multiple issues with the Pinephone MTXP 12 2,504 12-28-2023, 07:55 AM
Last Post: MTXP
  pinephone repair shop shengchieh 0 543 12-26-2023, 02:42 PM
Last Post: shengchieh
  sudo nano file saving pinephone beta edition CharlesGnarley 4 1,789 12-22-2023, 03:44 PM
