New PBP vpn connectivity?
Ok so I usually use express vpn, but it seems there is no aarch linux support. So I see the the PBP has openvpn already installed. Being that Ive never used it and also Im a linux newb, I opted to install the netwrok manager GUI, but apperently that isn't supported either. So how do I activate openvpn properly, or how can I get the GUI working? Thank you very much.
Exclamation Alpha One - no connectivity directly out of the box. anoduck 0 730 12-06-2025, 10:07 AM
Last Post: anoduck
