Terminal in Remix OS
Is there a way to pull up the terminal in Remix so I can check what is going on with my USB Wifi device. I cannot get any android image to recognize it.
(05-19-2016, 01:12 PM)jpecora93 Wrote: Is there a way to pull up the terminal in Remix so I can check what is going on with my USB Wifi device. I cannot get any android image to recognize it.
Remix OS based from Android build and I don't think USB Wifi device has been supported,
There's terminal apps in the play store that use busybox to get a terminal and standard tools.
However for USB device, I would think that it would depend of the kernel.
  sourround sound - Remix MrSarkasmus 0 2,863 10-05-2018, 05:05 AM
Last Post: MrSarkasmus
Star Remix OS 2.0 Image Release 20160718 tllim 25 44,346 08-30-2018, 01:21 PM
Last Post: Idemdesign
  Remix os os 64bits ?? Matroxplay 1 4,310 07-14-2018, 11:48 AM
  Remix OS NMancuso 111 165,295 08-01-2017, 03:51 AM
Last Post: wappi
Question Nginx proxy on Remix OS -- possible? mitchmitchell 1 4,776 05-29-2017, 02:45 AM
Question Remix OS 2.0 [20170105] Waaaa??? veronicasmithen03 1 4,711 05-29-2017, 02:42 AM
  REMix OS Boots and then blank Screen Michaelrowe01 6 19,426 04-17-2017, 04:20 AM
Last Post: simplexdan
  Stuck at Remix OS logo leongzhi 9 24,622 12-21-2016, 08:09 AM
Last Post: Michaelrowe01
Exclamation LCD TOUCH SCREEN PANEL support in Remix? mcfly777 4 8,928 12-19-2016, 07:49 PM
Last Post: Toriless
  Guest Account in Remix OS cannot Get Internet Connection deniyulianti 1 4,295 10-15-2016, 07:16 AM
Last Post: MarkHaysHarris777
