A hint for getting mobile data.
Not sure why but data only seems to work if you only have one set of APN settings. This means for now if you try setting up both mms and data APN settings, neither will work. Even if you turn one off, it's existence will block the other. Im guessing most will prioritize data these days so if you have put mms settings in, for now you'll need to delete them completely, not just turn them off. Then restart and enter your carriers data APN settings and you should be good to go.
At some point this bug should be addressed so we can have multiple APN settings.
Btw, im curious. If we manually enter APN settings rather than auto, how does that affect our connection when travelling/roaming outside our network?
  No Calling/texting/Data syrinx 23 26,360 03-11-2021, 11:00 AM
Last Post: andybleaden@gmail.com
  Mint Mobile & Pine Phone Lt. Dillinger 10 15,635 08-14-2020, 04:00 PM
Last Post: klick
  Mobile data APN Cree 0 2,106 07-27-2020, 11:47 PM
Last Post: Cree
  AT&T Cellular Data Athansor 8 9,794 07-23-2020, 08:03 AM
Last Post: Athansor
Bug Cellular Data vicky 4 5,847 07-01-2020, 04:06 AM
Last Post: fernando_c_m
  Mobile network settings afigegoznaet 2 3,640 05-18-2020, 01:29 PM
Last Post: afigegoznaet
  Mobile data issue on UT afigegoznaet 6 7,226 05-12-2020, 10:47 AM
Last Post: brb78
