slow wired network
Question
after having troubles with everything using network access, i tested network speed of my pine 64 2GB.
on a 50Mb/5Mb connection, which works fine for other devices, my pine cannot get more throughput than 440kb/3kb.
is this usual behaviour or is something wrong with my pine? (i'm running the android 20160505 8GB DD image)
(05-17-2016, 01:40 PM)bongo Wrote: after having troubles with everything using network access, i tested network speed of my pine 64 2GB.
Its a known issue. There are work arounds-  like slowing down the connection to ethernet 100 (instead of GB).
There are many threads on this problem, feel free to follow along e.g. here or here. I am sure that there are many many more you can find on the forum.
oh, i thought that my switch port was running at 100m. but to be sure, i'll move the pine to a switch which does not support more than 100m.
thanx for the hint!
(05-17-2016, 11:14 PM)bongo Wrote: oh, i thought that my switch port was running at 100m. but to be sure, i'll move the pine to a  switch which does not support more than 100m.
thanx for the hint!
Has it worked? If no make sure to come back here and I will try to help you out Smile
[edit] which image are you running ?
  Kodi Network Diviuss 4 5,977 08-19-2016, 12:51 AM
Last Post: Diviuss
  Extremely slow image download willyfog 9 12,257 06-27-2016, 08:46 AM
Last Post: lennychuck
  Mounting network NFS/CIFS shares simmo 1 5,395 05-28-2016, 09:14 PM
Last Post: UnixOutlaw
  Slow Internet connection android 5 and remix os lucassou 3 6,590 05-01-2016, 12:54 AM
Last Post: mattcozi
  network kdarius 0 1,373 04-27-2016, 10:01 AM
Last Post: kdarius
