Mobian snd_seq not installed
I've been trying to get Mame and a midi sequencer called "drumstick" to work on Mobian, and I keep getting an error where /dev/snd/seq file or directory not found.
Both crash while starting
Apparently the kernel was compiled without CONFIG_SND_SEQUENCER set, therefore snd_seq wasn't compiled into the kernel.
Can the flag be set in an upcoming update? I don't even know what the sound hardware on the Pinephone is.
Also there doesn't appear to be a modprobe for Mobian.
ScummVM works, (I played Full Throttle with full audio, no problems) and I suspect the error has something specific to do with MIDI sequencing.
edit: modprobe's there, I forgot to sudo when I ran it and just assumed it too was missing.
Thanks for reporting this issue! Sequencer support is now included in the latest kernel, once you upgrade and reboot Smile
(07-21-2020, 04:50 PM)a-wai Wrote: Thanks for reporting this issue! Sequencer support is now included in the latest kernel, once you upgrade and reboot Smile
BLESS YOU!
  bookworm vs trixie discussion for mobian in pinephone regular. zetabeta 21 2,171 11 hours ago
Last Post: anonymous
  Mobian repository status henrythemouse 16 8,832 04-10-2024, 10:02 AM
Last Post: diederik
  cant verify mobian image at website gnugpg penguins_rule 0 140 03-18-2024, 08:54 PM
Last Post: penguins_rule
  mobian installed to eMMC - how to install tow-boot grump_fiddle_reinstall 6 2,022 11-22-2023, 11:46 AM
Last Post: aLoop100o
  How to check if tow-boot is installed? jojuma 3 957 09-29-2023, 11:29 PM
  What actions needed to keep on mobian testing user641 3 1,843 09-05-2023, 06:44 AM
  Mobian boot failed with zstd message after upgrade. Mahgue 0 643 09-01-2023, 11:29 AM
Last Post: Mahgue
  Why is Firefox ESR not listet under "Installed" in "Software" jojuma 0 601 08-30-2023, 03:23 PM
Last Post: jojuma
  how to update mobian over tor vusra 13 6,948 07-09-2023, 08:57 PM
Last Post: vusra
  opensnitch outbound firewall now works on mobian vusra 2 1,913 07-09-2023, 01:37 AM
Last Post: vusra
