no more access to google play
Question
i installed the 20160505 android version (non rooted).
after booting, the pine first told me it was updating apps, and then seemed to work.
when i opened google play, i was able login and i saw my apps. then the pine immediately started downloading and installing updates.
first one was "android system webview", which took several hours to download (at only a few kb/s).
after doing so, i don't have access to google play anymore, i.e. i can open google play an select an app, but instead of downloading, it says "..blabla..could not be downloaded because of an error (error retrieving information from server [DF-DLA-15])".
i uninstalled the webview update, but it's still the same. no more download from google play.
btw: internet access using chrome still works without problems, but i get no download access to google play, i.e. i cannot install any apps.
what's going wrong? am i the onlyone having this problem?
I had the same problem, I had to do a 'Backup and Reset' and after that everything seems to work fine.
But the strange this was, I actually had a unrooted version of Android Image but once i did a 'Backup and Reset', it became rooted with SuperSU installed.
hm. so now i tried this:
i did a factory reset (i think that's what you meant), reentered my google account data, and now, whatever i do on google play, ends in a "connection timeout".
connection seems to be much more instable than it used to be at the beginning (after installing the android image).
in the mean time, it worked to install an app from google play, but network connection (wired) does not work most of the time.
usually, transfer rate does not get above 10kb/s, and often, there's no data at all transferred ;-(
  Microphone for Ok Google actions moondark 11 15,055 02-15-2018, 11:08 PM
Last Post: xnadoo
  GPIO access running Android rddragon888 20 28,939 11-06-2017, 07:18 AM
Last Post: Anvesh Reddy
  No Intenet Access Need Help Diagnosing Underlying Issue Bob123456789 10 11,133 06-02-2017, 01:32 PM
Last Post: Bob123456789
Thumbs Up Kids love to Play Super Why App Erica Edwards 3 4,626 01-09-2017, 07:35 PM
  Play music won't play anything mikey0000 12 15,441 10-21-2016, 01:24 PM
Last Post: gezora
  Guest Account Cannot Access Internet on Remix OS and Android x-86 OS deniyulianti 1 3,104 10-21-2016, 05:38 AM
Last Post: MarkHaysHarris777
  Guest Account in Android x-86 OS cannot Access Internet deniyulianti 0 2,143 10-15-2016, 07:30 AM
Last Post: deniyulianti
  I can get Internet Access, Though I cannot Use Instant Messagings (LINE, Zalo, Viber) deniyulianti 0 2,188 10-15-2016, 07:29 AM
  play store auth issue chrwei 29 32,090 09-09-2016, 11:02 AM
Last Post: eldaria
  Can't download apps off Google Play! Bacon Strips 6 8,521 08-31-2016, 12:26 PM
Last Post: DonFL
