Pinephone battery
I ve read somwhere that battery life for the Pinephone when always running is about two hours. That s too short for my purpose. I ve serached everywhere to find bigger Samsung J7 battereies. Unfortunately, I could not find any.  I have to find a solution with a external power bank. But the usb-c connector is not optimal for this. I miss an adapter from the Pinephone battery connector to usb power.
(07-29-2020, 03:34 AM)Peter Gamma Wrote: I ve read somwhere that battery life for the Pinephone when always running is about two hours. That s too short for my purpose. I ve serached everywhere to find bigger Samsung J7 battereies. Unfortunately, I could not find any.  I have to find a solution with a external power bank. But the usb-c connector is not optimal for this. I miss an adapter from the Pinephone battery connector to usb power.
You could look into the power connections on the Pogo Pins. I think they're intended to be used both for powering devices using the i2C, and for external power such as a back cover with battery, or wireless charging adapter. I think there's some question as to the accuracy of the documentation (3.3V pin actually 5V?), so you should check and probably measure before using it.
Thank you for your detailed answer, Wibble. But I think I will choose an usb-c hub with an additional connector to attach a power bank:
https://forum.pine64.org/showthread.php?...5#pid73465
The Pinephone battery would then only serve a second battery to protect from power loss loss.
  Pinephone boot. Richy_T 2 38 6 hours ago
Last Post: zetabeta
  PinePhone - boot from microSD laserpyramid 9 838 05-03-2024, 10:09 AM
Last Post: laserpyramid
  pinephone virtual keyboard aular 4 415 04-10-2024, 03:45 PM
Last Post: aular
  PinePhone Doesn't Boot LED Doesn't Show Any Signs When Charging dorkydev 1 280 04-02-2024, 11:50 AM
  Are you using the Pinephone as your daily driver? jro 157 110,690 02-18-2024, 11:33 PM
Last Post: aular
  2020 PinePhone Manjaro CE EU for sale, name your price astrojuanlu 7 1,918 02-14-2024, 04:51 PM
Last Post: astrojuanlu
  pinephone is not bootble for the box. ijij 1 658 01-19-2024, 01:29 PM
Last Post: fxc
  Multiple issues with the Pinephone MTXP 12 2,494 12-28-2023, 07:55 AM
Last Post: MTXP
  pinephone repair shop shengchieh 0 535 12-26-2023, 02:42 PM
Last Post: shengchieh
  sudo nano file saving pinephone beta edition CharlesGnarley 4 1,778 12-22-2023, 03:44 PM
