calculator
calculator is a good application however I use the inverted Polish notation (RPN) on a daily basis.
galculator is a calculator based on GTK 2 / GTK 3 with ordinary notation and Reverse Polishing Notation (RPN).
is it possible to replace calculator with galculator?
You can just install it.
sudo apt install galculator
(06-16-2020, 02:28 PM)Boern Wrote: You can just install it.
Yes, I had galculator installed with software.
In software, it is not possible to delete calculator.
but we can remove it with apt remove gnome-calculator.
