Pinephone UBport Edition no OS preinstalled
(06-09-2020, 12:16 AM)Bouc Wrote:
(06-08-2020, 08:52 PM)Aberts10 Wrote: You followed the other steps before doing that? You have to be in jumpdrive mode (Recovery mode basically)
I've followed every step. All was ok, I see the orange robot and i read the 'Welcome to Rescue SD Shell!'.
The first error is when I try to unmount /dev/mmcblk2p10.
Make sure the partition isn't open in your file browser or anything. I know cinnamon desktop does a auto-mount by default. Not sure what your using.
I use Mint XFCE with Thunar, the partitions are mounted automatically when I plug the Phone. First I unmount the partition, after I eject them.
Ubuntu Touch installed on memory card is ok. The problem is the internal memory.
(06-09-2020, 02:19 PM)Bouc Wrote: Ubuntu Touch installed on memory card is ok. The problem is the internal memory.
Try disabling auto-mounting of the drive in thunar. Then eject, replug the phone, and try again. I had trouble with nemo's automounting.
  ADB support on Pinephone Sumwun 3 884 09-27-2023, 04:04 PM
Last Post: Sumwun
  Ubuntu Touch vs Standard Pinephone OS MarsColonist 8 5,875 06-26-2023, 07:50 AM
Last Post: gregb49
  PinePhone and PinePhone Pro 20.04 Focal Install and Update c3l@ 0 743 05-12-2023, 05:06 AM
Last Post: c3l@
  Reinstall Ubuntu Touch on PinePhone with 10 drives? Peter Gamma 4 2,898 05-24-2022, 06:42 AM
Last Post: Peter Gamma
  PinePhone UBPorts Edition stuck on PINE64 logo screen Giovanni Iannotti 4 4,983 09-01-2021, 01:20 PM
Last Post: Giovanni Iannotti
  Images won't boot past pinephone logo remington_luger 9 9,759 08-22-2021, 09:56 AM
Last Post: remington_luger
  GhostCloud workaround for PinePhone mark1250 1 3,221 08-12-2021, 02:53 AM
Last Post: Uturn
  Looks like I found a mild reason why UBPorts for pinephone hasn't seen much progress. plainenough 13 17,645 11-21-2020, 06:30 PM
Last Post: Nooblife
  "No network" on new UBPorts community edition pinephone professorsnapper 6 7,940 10-19-2020, 10:27 PM
Last Post: htc_tattoo
  Horrible energy consume on Pinephone/UB-Touch firefox-58 9 11,678 10-15-2020, 12:28 PM
Last Post: plainenough
