The camera does v4l2
I haven't brought myself to install Cheese because it's Gnome.  But I have another USB webcam (which this is) and even in OpenBSD it can do v4l2 (Video For Linux 2).  I'm In Bullseye, I did
modprobe uvcvideo and lsusb shows (maybe it did before):
Bus 002 Device 003: ID 0c45:6321 Microdia HP Integrated Webcam
Installed a few v4l2 things, I don't really know what I'm doing.
v4l2-ctl --list-devices
rockchip,rk3399-vpu-enc (platform: hantro-vpu):
/dev/video0
/dev/video1
/dev/media0
rockchip-rga (platform:rga):
/dev/video4
USB Camera: USB Camera (usb-fe3c0000.usb-1.2):
/dev/video2
/dev/video3
/dev/media1
v4l2-ctl --all
Driver Info:
Driver name      : hantro-vpu
Card type        : rockchip,rk3399-vpu-enc
Bus info        : platform: hantro-vpu
Driver version  : 5.7.19
Capabilities    : 0x84204000
Video Memory-to-Memory Multiplanar
Streaming
Extended Pix Format
Device Capabilities
Device Caps      : 0x04204000
Streaming
Extended Pix Format
Media Driver Info:
Model            : hantro-vpu
Serial          :
Media version    : 5.7.19
Hardware revision: 0x00000000 (0)
Interface Info:
Type            : V4L Video
Entity Info:
Function        : V4L2 I/O
Pad 0x01000002  : 0: Source
  Link 0x02000008: to remote pad 0x1000004 of entity 'rockchip,rk3399-vpu-enc-proc': Data, Enabled, Immutable
Priority: 2
Format Video Capture Multiplanar:
Width/Height      : 96/32
Pixel Format      : 'JPEG' (JFIF JPEG)
Field            : None
Number of planes  : 1
Flags            :
Colorspace        : JPEG
Transfer Function : Default
YCbCr/HSV Encoding: Default
Quantization      : Default
Plane 0          :
  Bytes per Line : 0
  Size Image    : 6745
Format Video Output Multiplanar:
Pixel Format      : 'YM12' (Planar YUV 4:2:0 (N-C))
Field            : None
Number of planes  : 3
Flags            :
Colorspace        : JPEG
Plane 0          :
  Bytes per Line : 96
  Size Image    : 3072
Plane 1          :
  Bytes per Line : 48
  Size Image    : 768
Plane 2          :
  Bytes per Line : 48
  Size Image    : 768
JPEG Compression Controls
            compression_quality 0x009d0903 (int)    : min=5 max=100 step=1 default=50 value=50
And
v4l2-compliance -d /dev/video4 -s
v4l2-compliance SHA: not available
, 64 bits, 64-bit time_t
Compliance test for rockchip-rga device /dev/video4:
Driver Info:
Driver name      : rockchip-rga
Card type        : rockchip-rga
Bus info        : platform:rga
Capabilities    : 0x84208000
Streaming
Extended Pix Format
Device Capabilities
Device Caps      : 0x04208000
Streaming
Extended Pix Format
Required ioctls:
test VIDIOC_QUERYCAP: OK
Allow for multiple opens:
test second /dev/video4 open: OK
test VIDIOC_G/S_PRIORITY: OK
test for unlimited opens: OK
test invalid ioctls: OK
Debug ioctls:
test VIDIOC_DBG_G/S_REGISTER: OK (Not Supported)
test VIDIOC_LOG_STATUS: OK (Not Supported)
Input ioctls:
test VIDIOC_G/S_TUNER/ENUM_FREQ_BANDS: OK (Not Supported)
test VIDIOC_G/S_FREQUENCY: OK (Not Supported)
test VIDIOC_S_HW_FREQ_SEEK: OK (Not Supported)
test VIDIOC_ENUMAUDIO: OK (Not Supported)
test VIDIOC_G/S/ENUMINPUT: OK (Not Supported)
test VIDIOC_G/S_AUDIO: OK (Not Supported)
Inputs: 0 Audio Inputs: 0 Tuners: 0
Output ioctls:
test VIDIOC_G/S_MODULATOR: OK (Not Supported)
test VIDIOC_ENUMAUDOUT: OK (Not Supported)
test VIDIOC_G/S/ENUMOUTPUT: OK (Not Supported)
test VIDIOC_G/S_AUDOUT: OK (Not Supported)
Outputs: 0 Audio Outputs: 0 Modulators: 0
Input/Output configuration ioctls:
test VIDIOC_ENUM/G/S/QUERY_STD: OK (Not Supported)
test VIDIOC_ENUM/G/S/QUERY_DV_TIMINGS: OK (Not Supported)
test VIDIOC_DV_TIMINGS_CAP: OK (Not Supported)
test VIDIOC_G/S_EDID: OK (Not Supported)
Control ioctls:
test VIDIOC_QUERY_EXT_CTRL/QUERYMENU: OK
test VIDIOC_QUERYCTRL: OK
test VIDIOC_G/S_CTRL: OK
test VIDIOC_G/S/TRY_EXT_CTRLS: OK
test VIDIOC_(UN)SUBSCRIBE_EVENT/DQEVENT: OK
test VIDIOC_G/S_JPEGCOMP: OK (Not Supported)
Standard Controls: 5 Private Controls: 0
Format ioctls:
test VIDIOC_ENUM_FMT/FRAMESIZES/FRAMEINTERVALS: OK
test VIDIOC_G/S_PARM: OK (Not Supported)
test VIDIOC_G_FBUF: OK (Not Supported)
test VIDIOC_G_FMT: OK
test VIDIOC_TRY_FMT: OK
fail: v4l2-test-formats.cpp(836): fmt_cap.g_colorspace() != col
test VIDIOC_S_FMT: FAIL
test VIDIOC_G_SLICED_VBI_CAP: OK (Not Supported)
test Cropping: OK
test Composing: OK
test Scaling: OK
Codec ioctls:
test VIDIOC_(TRY_)ENCODER_CMD: OK (Not Supported)
test VIDIOC_G_ENC_INDEX: OK (Not Supported)
test VIDIOC_(TRY_)DECODER_CMD: OK (Not Supported)
Buffer ioctls:
test VIDIOC_REQBUFS/CREATE_BUFS/QUERYBUF: OK
test VIDIOC_EXPBUF: OK
test Requests: OK (Not Supported)
Test input 0:
Streaming ioctls:
test read/write: OK (Not Supported)
test blocking wait: OK
fail: v4l2-test-buffers.cpp(256): g_field() == V4L2_FIELD_ANY
fail: v4l2-test-buffers.cpp(1278): buf.qbuf(node)
test MMAP (no poll): FAIL
test MMAP (select): FAIL
test MMAP (epoll): FAIL
test USERPTR (no poll): OK (Not Supported)
test USERPTR (select): OK (Not Supported)
test DMABUF: Cannot test, specify --expbuf-device
Total for rockchip-rga device /dev/video4: 52, Succeeded: 48, Failed: 4, Warnings: 0
So it's on /dev/video4 as a device name anyway.
There, try this:
#!/bin/bash
adate=`date +"%Y-%m-%d_%H-%M"`
uvccapture -d/dev/video2 -v -x1600 -y1200 -o$adate.jpg
Needs uvccapture, it's in the debs.  Not sure about exposure control, the sun's coming in the window and it looks overexposed.  Why it's not video4 I'm not sure, that didn't work so I kept stepping down one at a time until one worked.  The Raspberry Pi cameras send on different "ports", not sure if that's like a TCP/IP port or not.  video4 may be for actual video.
My actual first picture:
There's a guy I stumbled across, I think in Australia, that does a lot with v4l2, virtual reality, OpenGL.  I think he works for Google now.  He does object recognition more by shape than by looking at pixels.  Uses those cool visors with tiny screens inside, wearable computers.  So finding this does v4l is very significant.  Focusing would be good, I have cell phone cameras that can focus.
This guy: http://www.tinmith.net/ Dr Wayne Piekarski
And for video there's guvcview.  I've hit my attachment quota so I can't post my screenshot just now.  I do have an Imgur account, have to dig up the password.  I guess I wasn't paying attention, I thought the image quotas were a per month thing.
[Image: NqAm7LO]
https://imgur.com/gallery/NqAm7LO
  Camera not working with Cheese cypresstwist 1 1,290 08-18-2023, 02:02 AM
Last Post: juliamenendez
  Can we get a latest camera fix in Debian? Krakatau 0 1,620 01-07-2020, 05:31 PM
Last Post: Krakatau
