10-24-2020, 10:55 AM
Recently I've been having a problem with the rubber feet coming off the bottom.
The worst ones are the ones on the back side (nearer to the screen). They have the habit of sliding around on the underside if the laptop is pushed. Or even worse, coming off in the bag and getting potentially lost. And if the feet are not in the proper place the laptop will wobble around and of course the glue is sticky as well.
I'm asking if anyone else has had the same issue and what did you do? I'm thinking that there could be replacement feet or some adhesive that can glue them back more securely.
