Phone dead.
OK, I charged the phone up for the first time and was able to turn it on and after a while it went dead.
Tried to recharge it but no indicator light to say its charging.
Any ideas?
Thanks.
Sent from my LYA-L09 using Tapatalk
have you looked at the posting further down re charging etc
or here
https://forum.pine64.org/showthread.php?tid=9105
(05-22-2020, 09:28 AM)colin hodsdon Wrote: have you looked at the posting further down re charging etc
or here
I'll take a look.
Thanks.
Well, I've tried to reset the phone and used a different USB cable but seems the phone is completely dead.
I'm really peeved off with pine that I paid for a phone that stopped working within the hour of switching on for first time.
Did you only ever get it to turn on when plugged in? Sounds like maybe you didn't remove the battery isolator tab.
....  In the past,  phones often came with the battery not installed,  but packed inside the same box as the phone
   Have you removed the battery isolation tape from the phone ?    (Carefully !)
I noticed the phone is not charging on the computer or other cheap wall chargers. Be sure you use a powerful one (I only can charge it in the UPS). I think I read your charger has to be at least 3V.
the USB spec is 5 volts, so no charger should ever be less than 5 volts. the only variance should be in amperage, which varies by USB spec
  Looking for the "non-phone" OS wakyct 7 1,634 03-14-2024, 03:51 AM
Last Post: MTXP
  Writing apps/programs for pine phone katesfb 7 5,389 03-11-2024, 10:42 PM
Last Post: Emelia525
  How To Access the Pine Phone Auxillary microSD Without Removing Card pinephoneuser22 2 1,134 01-09-2024, 07:02 PM
Last Post: britelite
  Can the Pine Phone be serviced and updated remotely? profileyourcity 3 1,223 10-02-2023, 05:19 PM
  UBports on pine phone? robb777 16 4,270 09-01-2023, 04:26 AM
Last Post: gregb49
  US Cell Phone Service Providers with prices and phone numbers - UPDATED jovval 0 783 07-01-2023, 01:25 AM
Last Post: jovval
  Loving my pine phone after about a year of not undata 0 757 05-11-2023, 02:23 PM
Last Post: undata
  New Pinephone is dead. eMMC, boot, hardware issues. Shane 4 1,626 05-10-2023, 03:31 AM
Last Post: fxc
  New Phone Opening Issues LuluFrance 5 2,366 03-15-2023, 05:33 AM
Last Post: anonymous
  pine phone external speaker AnAbolitionist 9 3,744 02-08-2023, 01:11 AM
Last Post: robb777
