10-29-2018, 04:23 AM
I want to run Centos 7 on rock64 rk3328 chipset. Any sort of help is appreciated.
Regards,
Regards,
Centos 7 on rock64
Regards,
12-12-2018, 12:24 PM
(10-29-2018, 04:23 AM)smnoufal Wrote: I want to run Centos 7 on rock64 rk3328 chipset. Any sort of help is appreciated. Hi smnoufal, I would try to see if you can get any armbian rock64 distribution to work on it. If that works then you can try sliding the centos 7 file system on it. For inspiration see what I did for pine64 here: https://github.com/Project31/centos-pine64 Cheers, --Kurt
12-25-2018, 07:27 AM
(12-12-2018, 12:24 PM)kurtstam Wrote:Thanks Kurt,(10-29-2018, 04:23 AM)smnoufal Wrote: I want to run Centos 7 on rock64 rk3328 chipset. Any sort of help is appreciated. I will have a look on the above link.
12-26-2018, 12:29 PM
(12-25-2018, 07:27 AM)smnoufal Wrote:Hi Kurt,(12-12-2018, 12:24 PM)kurtstam Wrote:Thanks Kurt,(10-29-2018, 04:23 AM)smnoufal Wrote: I want to run Centos 7 on rock64 rk3328 chipset. Any sort of help is appreciated. I have inserted empty microsd and run install.sh, i am stuck on screenshot attached
01-16-2019, 07:02 PM
Hi smnoufal,
You can try the ready to go image: https://project31.github.io/pine64/. I've created it running from the rock64 branch on https://github.com/Project31/centos-pine64/tree/rock64. Cheers, --Kurt
01-18-2019, 06:23 AM
Thanks Kurt, for centos 7 on rock64,
I followed your instruction and glad to inform you that successfully loaded cenntos 7. once i tried to enlarge the sd card and rebooted as per your instruction and it ffiled to boot. I think partition got deleted. smnoufal kurtstamHi smnoufal, You can try the ready to go image: https://project31.github.io/pine64/. I've created it running from the rock64 branch on https://github.com/Project31/centos-pine64/tree/rock64. Cheers, --Kurt Log in to use Ginger Limited mode centos [url=javascript:]×[/url]
01-21-2019, 09:20 AM
Hi smnoufal,
1. So I take it then things work ok /before/ you try to enlarge the partition on the sd card? 2. I would re-flash the image and start over. I would try to take baby steps so you can pinpoint what works for you. Whenever you work fdisk you have to be careful.. Double check:
Cheers, --Kurt |
Fedora 32/CentOS 8 Pine A64+ Images | wideawake | 2 | 5,561 |
10-02-2020, 11:38 AM Last Post: mathiraj |
NEMS Linux 1.5 Released for A64/A64+, A64-LTS/SOPine, Rock64, RockPro64 (NAGIOS) | Baldnerd | 4 | 9,398 |
03-28-2020, 06:20 PM Last Post: ty1911 |
Centos 7 for Pine A64 | Luke | 2 | 6,150 |
05-28-2019, 12:18 AM Last Post: pineadmin |
Centos 7 | ebrand | 12 | 21,782 |
01-12-2019, 06:40 PM Last Post: astr0baby |
Making a DVD Server (including burning) using Rock64 | Ron Piggott | 1 | 3,306 |
04-11-2018, 08:33 AM Last Post: dkryder |
