Any plans for Rock64 mk 2?
To make it stronger competitor to others?
Now it is weaker in comparing to Asus TinkerBoard. Especially from Mali performance perspective. I mean better CPU architecture gives piko gain over RK3288 of Tinker, yet it is worth to note that Rock64 is driven by 1.3GHz CPU while Tinker - 1.8GHz. But Rock64 wins by supporting USB3, however is almost 2x slower when using advanced OpenCV algorithms.
Czesc Akradiusz Smile Suggest you read the IRC logs - you just may find some hints what's in stock for the future.
It looks like there is a "Transformer" product though it's the same SoC so the details you were comparing won't change; Looks like an Odroid-HC1 but with less software support
[Image: k3ow3oI.jpg]
Less software support ?
(12-01-2017, 04:12 AM)Arkadiusz Wrote: To make it stronger competitor to others?
There will be a ROCKpro64 board roll out in early 2018 that features RK3399, dual A72/quad A53 code, MALI T860MP4 which can boost 20% more performance over RK3288 T764.
(12-02-2017, 04:35 PM)Luke Wrote: Less software support ?
Speaking of pine64 leaving Wayland/GNU/Linux to the community there will soon be a rockchip with dd4 and maybe GNU support;
https://libre.computer/products/boards/roc-rk3328-cc/
Hurrah for microUSB power ! ... wish them best of luck with that Wink
(12-08-2017, 05:30 AM)Luke Wrote: ... microUSB power...
10W microUSB is common and works well for the market leader (rpi), would be nice to see a '45W USB-C Power Adapter' but that's likely a needless expense .
Thanks for hint!
Wonder how this new board will match to the current Rock64? I guess diameters & sockets location does not change.
But main thing is Ethernet/USB3 speed. With Rock64 eth max speed is 550Mbps (while on the same cable Tinker achives 920Mps) while on USB3 my 6Mpx USB3vision camera tops 120MB/s only (while supports 60fps,i.e 360 MB/s)
Is there any news for rockpro64?
  Rock64 No Audio @ Debian 12 dmitrymyadzelets 2 516 04-08-2024, 06:47 AM
Last Post: dmitrymyadzelets
  OpenWRT on the Rock64 CanadianBacon 14 8,826 04-03-2024, 08:48 AM
Last Post: helpmerock
  Rock64 bricked shawwwn 7 5,954 03-17-2024, 12:22 PM
  Rock64 won't boot luminosity7 10 4,568 03-16-2024, 08:33 AM
  Rock64 doesn't boot dstallmo 1 428 03-16-2024, 08:29 AM
  How well does Rock64 deal with HDR and Atmos on Kodi? drvlikhell 3 2,089 04-29-2023, 04:24 AM
Last Post: newestssd
  Rock64 board not working, no HDMI no Ethernet. EDited 3 3,685 01-17-2023, 02:31 PM
Last Post: Flagtrax
  ROCK64 v3 can it boot from USB? Tsagualsa 4 2,285 11-29-2022, 11:31 AM
Last Post: Macgyver
  rock64 v3 spiflash Macgyver 0 812 11-28-2022, 02:18 PM
Last Post: Macgyver
  my rock64 dosen't work rookie_267 0 1,014 10-07-2022, 07:50 PM
Last Post: rookie_267
