I'm concerned about how to connect the controller wirelessly.
I haven't got my rock64, just curious.
I have a Logitech K 400 plus ... has worked flawlessly,on all the rock 64 images I've tried.
[I am having problems with USB ports not working, after the login screen, in some builds, but am still working on narrowing it down .. I plan to post on it, once I can define exactly when, on what OS ISO it is happening. I can say ..it is not a hardware problem .. I can always get to the login screen, and type, use trackpad no problem.. it is after that, that sometimes, the USB ports quit working .. as I said, when I can quantify the problem, will post more].
Jake
BT chipset that worked for me out of the box: CSR8510
09-27-2017, 01:57 PM
(This post was last modified: 09-27-2017, 01:58 PM by tarlo766.)
I bought ROCK64 USB BLUETOOTH BLE 4.0 (CSR8510 A10) from the store. I am not having any luck getting it work. I am plugging it into a USB2.0 slot with android 7.1 on 64GB eMMC on the Rock64 4GB. Not even sure how to "install" it as PnP doesn't seem to be supported. Any help would be appreciated. Thanks!
-Jon
