09-04-2016, 03:03 PM
Hello, I've installed my Pine64+ 2 GB model with Android 5.1.1 for LCD into my just arrived playbox enclosure along with the LCD screen. Everything is working well including the touchscreen in the LCD.
There is a setting within Android (Settings/Display/when Device is Rotated, rotate the Contents of Screen). This doesn't work for me.
This is slightly problematic for me as the power USB connection is on the bottom of the enclosure when the default screen orientation is active. If I could rotate the screen 180 degrees, then that plug would be on the top of the enclosure and out of the way while the enclosure is in my lap. I'm not using any USB devices, so, for me, having the USB ports on the bottom of the enclosure when the screen is rotated 180 degrees works better for me.
I know this is very minor, but I thought I'd ask if anyone has successfully rotated the screen in Android 5.1.1 for LCD. I'm using the latest build (20160603 LCD Panel Output). Or maybe I just need to wait for the next Android LCD build? Thanks.
