DC plug length
Can anyone please tell me the length of the DC plug? I know the outer diameter is 5.5 mm and the inner diameter is 2.1 mm, but I can't find the length (or even a part number for J11 that I could check, since there's no BOM published).
Hi, I just measured the plug on one of the power supplies I use for it and the part that inserts into receptacle is a bit under 10mm. Looking around, it seems like 10mm is the common length for this type of plug's insertion portion.
Occasional Linux Kernel Contributor, Avid Wiki Updater, Ask Me About Quartz64
Open Hardware Quartz64 Model A TOSLink Adapter
Pi-bus GPIO Extender For ROCKPro64 And Quartz64 Model A
Plebian GNU/Linux
(04-01-2023, 07:43 AM)CounterPillow Wrote: Hi, I just measured the plug on one of the power supplies I use for it and the part that inserts into receptacle is a bit under 10mm. Looking around, it seems like 10mm is the common length for this type of plug's insertion portion.
Thanks.  I wasn't sure if it was the typical 9.5 mm or something else like 10 mm.
It's ⅜". Exactly 0.375 inches, or 9.525mm.
:wq
[ SRA accepts you ]
Everyone wants me to quit using NetBSD
