08-13-2017, 01:14 PM
No ! DDR settings are not the same ...
Do I really need PINE64-Installer?
So, I have not any sd reader now - is it possible to burn an image to sd card from my pinebook?
I successfully run pine install, but it is not seeing any sd cards( I also tried this: Code: sudo dd bs=4M if=image.iso of=/dev/mmcblk1 And also have not succeed - I tried it with q4os-live-1.8.7-x64.iso. Where I can download images directly to try again dd thing? (08-13-2017, 04:41 PM)shirman Wrote: So, I have not any sd reader now - is it possible to burn an image to sd card from my pinebook? https://sourceforge.net/projects/q4os/fi...p/download On linux, some internal readers will put the sd card at /dev/mmcblkX and some internal and most external usb readers will put the sd card at /dev/sdX. You want to write your image directly to the start of the disk and not to a partition of it (since the image contains its own partition table). So for example, make sure you're not writing the extracted .img file to mmcblk0p1 or sdc2, you'd want mmcblk0 or sdc. An easy way to find the right drive is to run 'dmesg|tail' or 'lsblk' before and after you insert the card.
08-14-2017, 04:47 PM
lol, I used wrong image, for x64 system now all is fine, thank you
How to port Postmarket OS from Pine64-LTS to Pinebook | Surehand53 | 0 | 2,387 |
01-16-2019, 08:55 AM Last Post: Surehand53 |
Installer does not work for me | Tofu | 4 | 6,372 |
12-02-2018, 12:55 AM Last Post: Tofu |
Installer shows SD Card size 0GB | atr.mbl | 1 | 3,263 |
08-16-2017, 11:13 PM Last Post: MarkHaysHarris777 |
Pine64 Installer Utility | Luke | 0 | 6,336 |
04-26-2017, 04:57 AM Last Post: Luke |
