No external monitorvia USB-C over Dockingstation
I downloaded and extracted the 6.5 pbp.tar.gz as was directed.
https://xff.cz/kernels/6.5/pbp.tar.gz
When I extracted it, the /lib/modules/ directory did not contain something with 'dirty' on the end but was this:
/lib/modules/6.5.7-00508-gb1f5e9cc01a2
Should I try to use this or will the lack of 'dirty' mean that this is not the correct file and won't work?
Thank you much!
I used the Manjaro-ARM-xfce-pbpro-20.04-emmc-installer-20.04.img to install Manjaro on the eMMC, then updated it to the latest version.  Without doing anything else, a second monitor shows up automagically with HDMI via USB-C, but the sound doesn't work.
Does sound work with megi's kernel?
Meanwhile, I tried the last two versions of Armbian, and HDMI via USB-C doesn't work at all.
https://forum.pine64.org/showthread.php?tid=18852
(11-13-2023, 02:09 PM)zaius Wrote: I used the Manjaro-ARM-xfce-pbpro-20.04-emmc-installer-20.04.img to install Manjaro on the eMMC, then updated it to the latest version.  Without doing anything else, a second monitor shows up automagically with HDMI via USB-C, but the sound doesn't work.
How did you get this older version 20.04 of Manjaro? Do you have a link handy?
(11-21-2023, 07:33 PM)marty-mcfly Wrote: How did you get this older version 20.04 of Manjaro? Do you have a link handy?
There are two versions, one to run off SD, and an eMMC installer.
https://osdn.net/projects/manjaro-arm/st...fce/20.04/
There are also both versions with a KDE desktop https://osdn.net/projects/manjaro-arm/st...sma/20.04/
Unfortunately, osdn.net seems to have server issues.  So if the page doesn't load, I would try again later.
Also, when updating, if you get an error "nss: /usr/lib/p11-kit-trust.so exists in filesystem", this worked for me:
sudo pacman -Syu --overwrite /usr/lib\*/p11-kit-trust.so
https://gist.github.com/linuxkathirvel/6...86ab0a5764
Has anyone been able to get sound to work through HDMI?
I just tried Manjaro-ARM-gnome-pbpro-23.02.img from https://manjaro.org/download/ and HDMI via USB-C did not work.
I do not know the difference (besides the desktop and additional software) between that, and the updated Manjaro from OSDN.  However, I suspect that whoever wrote it did something the Armbian and Manjaro people are not doing, even with their PBP-specific distributions.
(Although the Gnome desktop seemed well-appointed, the Manjaro-ARM-gnome-pbpro-23.02.img also seemed unusually slow compared to the other distributions I've tried.)
  Manjaro ARM: enabling external monitors & fixing Broadcom WiFi after updating trifleneurotic 2 992 11-14-2023, 10:57 AM
Last Post: trifleneurotic
  Sleep and external display - Are there any options? chris88233 7 1,929 09-04-2023, 09:03 PM
Question External display doesn't work in TwisterOS (Armbian) TDC_PBP 0 1,576 08-21-2021, 02:46 PM
Last Post: TDC_PBP
  External USB C Monitor not working altacus 29 39,179 08-08-2021, 10:19 AM
Last Post: Dendrocalamus64
  External display stopped working, "dpcd read failed: -22" in dmesg zackw 3 5,485 05-01-2020, 03:14 AM
Last Post: Valinor
