UART stopped working
(04-23-2020, 02:28 PM)kuleszdl Wrote: The UART on my rock64 (using PINs 6, 8 and 10) stopped working after attaching it quite many times. Eventually I might have shortened something and damaged the board? Anyways, besides that the board itself seems to work fine. The same serial console is working with a rockpro64 so I am quite sure that it's a hardware issue (to be double-sure, I will try to double-check with a different rock64 from a collegue).
Anyways, is there any alternative UART that can be used? And what approach can you recommend to locate the fault?
There is no alternative UART can be used.
UART stopped working - by kuleszdl - 04-23-2020, 02:28 PM
RE: UART stopped working - by tllim - 04-29-2020, 11:07 PM
  Unterstanding RK3328 UART Interface Register Offsets krjdev 1 2,867 11-28-2022, 11:26 AM
Last Post: JeremyWadsworth
  Rock64 RTL8812AU dongle (from store) how to get working on Android? Nelly 4 6,287 02-07-2018, 10:28 PM
Last Post: varos16
  Cant make WiFi working on ROCK64. vieirabrazil 8 13,282 01-24-2018, 05:34 PM
Last Post: vieirabrazil
