No audio
(04-20-2020, 08:23 PM)evj Wrote: No audio on PBP as delivered. Read message about trying with another operating system. After much trouble I succeeded in booting OpenSuse (from microSD); still no sound. Am I not doing something (in config files), or have I got bad hardware?
In a terminal enter "sudo alsamixer". You will see the soundcard settings. On my PBP running Manjaro, the left most slider reading "headphone" is set to 0 by default. Setting it to 100 and pressing "ESC" to exit and I have normal sound.
You can store the settings using "sudo alsactl store", but they will be lost on reboot. Entering "sudo alsactl restore" brings them back. I have not found a way to get alsamixer to load these stored settings by default.
No audio - by evj - 04-20-2020, 08:23 PM
RE: No audio - by polypode - 05-21-2020, 03:12 PM
  Pinebook Pro - No Audio bebop_man 13 18,962 05-20-2020, 03:16 PM
Last Post: polypode
  USB C video and hub/net/audio/whatever Corkonian 1 2,867 11-15-2019, 11:36 PM
Last Post: deviantgnome
