OMV + VPN server + Pi Hole?
(03-16-2020, 08:36 AM)odhinnhrafn Wrote: So, I have a RockPro64 running OMV that I purchased last year some time.  It's in the NAS case with 2 4TB HDDs, running as separate drives.  It's been working great, with Emby plug in.  I had an issue where I lost power (hadn't bought a UPS yet), and the main media drive crapped out.  That's all solved.  Now, however, I'm looking at using a SBC to run a VPN server, and pi hole to remove ads from my network.  I was looking at an Odroid N2 to run this.  However, after some research, I'm thinking maybe I can run all 3 services on the RP64...  It seems to be powerful enough for it.  Is it wise to do an all in one, or should I keep them separated?
That should be fine. I'm running e.g. nextcloud/openVPN/tvheadend/syncthing/nginx/mariadb (several)/nfs/samba/aria2... and more mainly in docker containers.
One java application I had to move to my spare rockpro64, since it is a bit sensible when it comes to memory or timing issues..
I guess you are talking about a Home/small office server!
M
OMV + VPN server + Pi Hole? - by odhinnhrafn - 03-16-2020, 08:36 AM
RE: OMV + VPN server + Pi Hole? - by mabs - 03-16-2020, 10:37 AM
RE: OMV + VPN server + Pi Hole? - by odhinnhrafn - 03-16-2020, 10:51 AM
RE: OMV + VPN server + Pi Hole? - by mabs - 03-16-2020, 05:01 PM
  Smart TV & server storz 1 1,369 01-19-2024, 01:59 PM
Last Post: dairymilkbatman
  Home Server with RAID 1 SATA M2 SSDs runyor 7 2,580 09-26-2023, 09:14 AM
  Umbrel Server Shaeroden 0 1,359 05-04-2022, 06:14 PM
Last Post: Shaeroden
  SkiffOS server with Docker ,NAS, Home assistant, Jellyfin, Snikket XMPP (tutorial) GreyLinux 12 10,100 04-04-2022, 05:26 AM
Last Post: GreyLinux
  SimpNas server with docker - home assistant, radicale , jellyfin & esphome (tutorial) GreyLinux 0 4,416 01-17-2021, 11:33 AM
  [WIP] backup server (4 sata HDDs + ZFS) rolando 8 12,186 06-30-2020, 10:58 AM
Last Post: dml-pc
Video ARMBand an easily configured Home Media Server gabrielsr 2 6,204 07-22-2019, 04:56 AM
Last Post: stuartiannaylor
