Booting with modified kernel parameters?
Is there a way to do a one-off boot with changes to the kernel's "command line", ideally without opening up the PBP or attaching a serial console?  Like one would do on an x86 with GRUB by editing the menu entry.
I specifically want to interrupt the boot sequence while it's still running out of the initramfs and / isn't mounted, so that I can resize the partition, but I haven't been able to find anything on here talking about the general case.
I'm using the stock Debian install on the eMMC and I don't have a micro-SD card to put another OS instance on, unfortunately.
Booting with modified kernel parameters? - by zackw - 02-29-2020, 08:33 AM
  How to mainline kernel on daniel thompson's debian installer? hellojack 14 7,656 09-07-2023, 09:38 PM
  Issue with booting Manjaro from encrypted NVMe drive on pbp Cs137 1 1,005 08-18-2023, 01:58 AM
Last Post: juliamenendez
  kernel module that supports usb-c hdmi alexandre 16 14,885 05-14-2023, 09:58 PM
Last Post: rathofkhan3
  Fix for Armbian not booting on PBP from eMMC agreenbhm 7 3,973 04-01-2023, 02:58 PM
Last Post: TRS-80
Question Debian (Vanilla) no output on display after Kernel update (6.0.8-1) as365n4 1 1,309 12-09-2022, 12:43 PM
Last Post: as365n4
  Booting Arch from USB lorebett 6 3,110 09-18-2022, 11:35 AM
Last Post: lorebett
  pinebook pro not booting cricket 1 1,213 08-17-2022, 04:38 PM
Last Post: cricket
  PBP not booting anymore jsch 5 3,019 04-21-2022, 11:24 AM
  Problems installing/ booting a different Linux on PinebookPro v-man 3 3,139 03-22-2022, 06:37 PM
Last Post: pentamassiv
  bootloader menu to pick a kernel - what is the current situation in in early 2022? maxtothemax 4 3,207 02-05-2022, 03:04 PM
Last Post: maxtothemax
