No Android build working!
#55
I might have done something wrong. So please don't avoid trying it because of what happened to me. But do have a backup of your eMMC just in case.
FWIW, I used `dd` on a computer with NetBSD to create the working SD card. You could use `dd` in Manjaro on your PBP. I don't know the first thing about Etcher. I've heard lots of good things about it, and never heard anything bad about it. But `dd` is the most direct way to do this job. I can't imagine using anything else (in Unix/Linux).
dd if=file.img of=/dev/sd bs=4M status=progress
Should get the job done in Manjaro, I think. Of course, replace "file.img" with the correct image file. If it's zipped, unzip it first. (unzip file.img.bzip) You'll have to replace /dev/sd with the raw device for the SD card. I don't recall the device name for Manjaro; you might already know it. If you don't, let me know and I'll dig up that information.
No Android build working! - by pin - 02-18-2020, 07:34 AM
RE: No Android build working! - by tophneal - 02-18-2020, 10:11 AM
RE: No Android build working! - by pin - 02-18-2020, 10:40 AM
RE: No Android build working! - by tophneal - 02-18-2020, 10:52 AM
RE: No Android build working! - by pin - 02-18-2020, 11:22 AM
RE: No Android build working! - by MathieuDSTP - 02-27-2020, 04:30 PM
RE: No Android build working! - by decisivedove - 03-10-2020, 09:41 AM
RE: No Android build working! - by tophneal - 03-10-2020, 10:50 AM
RE: No Android build working! - by justiceankomah - 07-03-2021, 06:08 PM
RE: No Android build working! - by gibbio - 04-08-2020, 12:37 PM
RE: No Android build working! - by jiyong - 04-10-2020, 06:03 PM
RE: No Android build working! - by slow_motion - 06-17-2020, 03:03 PM
RE: No Android build working! - by jiyong - 06-17-2020, 03:44 PM
RE: No Android build working! - by slow_motion - 06-17-2020, 03:49 PM
RE: No Android build working! - by tophneal - 06-17-2020, 03:57 PM
RE: No Android build working! - by slow_motion - 06-17-2020, 11:56 PM
No Android build working! - by tophneal - 06-18-2020, 05:25 AM
RE: No Android build working! - by slow_motion - 06-18-2020, 06:11 AM
RE: No Android build working! - by tophneal - 06-18-2020, 06:30 AM
RE: No Android build working! - by slow_motion - 06-18-2020, 07:11 AM
RE: No Android build working! - by tophneal - 06-18-2020, 07:38 AM
RE: No Android build working! - by slow_motion - 06-19-2020, 02:54 AM
RE: No Android build working! - by tophneal - 06-19-2020, 06:14 AM
RE: No Android build working! - by slow_motion - 06-19-2020, 01:12 PM
RE: No Android build working! - by tophneal - 06-19-2020, 01:20 PM
RE: No Android build working! - by slow_motion - 06-19-2020, 01:24 PM
RE: No Android build working! - by tophneal - 06-19-2020, 01:31 PM
RE: No Android build working! - by slow_motion - 06-19-2020, 01:34 PM
RE: No Android build working! - by tophneal - 06-19-2020, 01:36 PM
RE: No Android build working! - by slow_motion - 06-19-2020, 02:11 PM
RE: No Android build working! - by tophneal - 06-19-2020, 02:12 PM
RE: No Android build working! - by slow_motion - 06-19-2020, 02:35 PM
RE: No Android build working! - by tophneal - 06-19-2020, 02:45 PM
RE: No Android build working! - by slow_motion - 06-19-2020, 02:52 PM
RE: No Android build working! - by tophneal - 06-19-2020, 03:25 PM
RE: No Android build working! - by slow_motion - 06-19-2020, 03:42 PM
No Android build working! - by tophneal - 06-19-2020, 03:45 PM
RE: No Android build working! - by slow_motion - 06-19-2020, 03:51 PM
RE: No Android build working! - by slow_motion - 06-20-2020, 02:18 PM
RE: No Android build working! - by firefox-58 - 07-13-2020, 05:17 AM
RE: No Android build working! - by erock22 - 07-17-2020, 08:31 PM
RE: No Android build working! - by tllim - 07-20-2020, 04:55 PM
RE: No Android build working! - by modifex - 07-22-2020, 11:17 PM
RE: No Android build working! - by KC9UDX - 07-22-2020, 11:37 PM
RE: No Android build working! - by tllim - 07-29-2020, 10:07 PM
RE: No Android build working! - by ovv - 08-18-2020, 08:34 AM
RE: No Android build working! - by tophneal - 08-18-2020, 09:01 AM
RE: No Android build working! - by ovv - 08-28-2020, 02:50 AM
RE: No Android build working! - by rempfer - 10-15-2020, 11:49 PM
RE: No Android build working! - by tophneal - 10-16-2020, 06:41 AM
RE: No Android build working! - by rempfer - 10-23-2020, 05:41 AM
RE: No Android build working! - by tophneal - 10-23-2020, 06:44 AM
RE: No Android build working! - by Vinay - 11-15-2020, 03:35 PM
RE: No Android build working! - by WhiteNoise - 01-07-2021, 03:35 PM
RE: No Android build working! - by KC9UDX - 11-15-2020, 03:46 PM
RE: No Android build working! - by Vinay - 11-16-2020, 12:57 AM
RE: No Android build working! - by KC9UDX - 12-28-2020, 05:49 AM
RE: No Android build working! - by KC9UDX - 01-07-2021, 06:54 PM
RE: No Android build working! - by Vinay - 02-16-2021, 08:13 AM
RE: No Android build working! - by tophneal - 02-16-2021, 08:58 AM
RE: No Android build working! - by Vinay - 02-16-2021, 02:06 PM
  Google on Android? KC9UDX 21 29,216 03-17-2023, 11:35 AM
  Getting platform tools working like I'm used to? bastafari 20 28,303 12-24-2020, 01:14 AM
Last Post: jonnyhawk
  MD5 On Android jaysistar 0 2,708 03-14-2020, 08:38 AM
Last Post: jaysistar
  Arguments for android support metcalsr 20 31,249 02-08-2020, 12:12 PM
Last Post: Idaho
Exclamation All android buillds on wiki for Microsd missing GPT? TDC_PBP 14 21,117 01-31-2020, 11:22 PM
  Any word about Android builds? tophneal 36 49,665 01-26-2020, 12:06 AM
Last Post: Account
  Flashing Updated U-Boot on Android tophneal 6 10,498 01-16-2020, 06:05 AM
