PinePhone RTL8723CS automatic test fail and WiFi problem
(02-13-2020, 05:58 AM)surfingtux Wrote: I run automated tests RTL8723CS is failing.
https://wiki.pine64.org/index.php/PinePhone
If RTL8723CS is failing:
"make sure there is Wifi router around 5 meter area when perform this test, the Wifi test function sniff for SSID to determine test result during autotest. The Wifi can fail if the battery power is too low. "
I tried with battery full and charger on but still automatic tests fail and there should be Wifi signals around.
And I have not got WiFi working with Ubports or Manjaro Alpha3.
Any one else having this problem?
Any ideas how to get it to work?
Or is the HW just faulty?
I think I remember someone else with the same problem got it to work by flicking the privacy switches from off to on and back again, YMMV.
RE: PinePhone RTL8723CS automatic test fail and WiFi problem - by pjsf - 02-13-2020, 04:10 PM
  eSIM on PinePhone just_a_q 3 2,668 Yesterday, 03:41 PM
Last Post: bam
Exclamation No wIfI after Mobian update crakabeats 4 2,231 05-10-2024, 06:45 AM
Last Post: 98cwitr
  Pinephone boot. Richy_T 4 175 05-06-2024, 08:32 AM
Last Post: Richy_T
  PinePhone - boot from microSD laserpyramid 9 930 05-03-2024, 10:09 AM
Last Post: laserpyramid
  pinephone virtual keyboard aular 4 460 04-10-2024, 03:45 PM
Last Post: aular
  PinePhone Doesn't Boot LED Doesn't Show Any Signs When Charging dorkydev 1 311 04-02-2024, 11:50 AM
  Are you using the Pinephone as your daily driver? jro 157 111,465 02-18-2024, 11:33 PM
Last Post: aular
  2020 PinePhone Manjaro CE EU for sale, name your price astrojuanlu 7 1,971 02-14-2024, 04:51 PM
Last Post: astrojuanlu
  pinephone is not bootble for the box. ijij 1 698 01-19-2024, 01:29 PM
Last Post: fxc
  Multiple issues with the Pinephone MTXP 12 2,630 12-28-2023, 07:55 AM
Last Post: MTXP
