Heat sink required for Pine64?
(05-03-2016, 09:20 PM)Leoncito81 Wrote: Most of the higher powered SBCs I've seen have a small heat sink if you're going to be running graphics. :-)
Thermal behaviour as well as the (non existing) need for heatsinks depending on the use case has been extensively researched on. All information publicly available as well as the tools to measure the stuff internally: http://forum.pine64.org/showthread.php?tid=389&page=5
RE: Heat sink required for Pine64? - by Beryllium - 05-03-2016, 05:13 PM
RE: Heat sink required for Pine64? - by g_t_j - 05-03-2016, 06:00 PM
RE: Heat sink required for Pine64? - by Beryllium - 05-03-2016, 06:31 PM
RE: Heat sink required for Pine64? - by g_t_j - 05-28-2016, 05:00 AM
RE: Heat sink required for Pine64? - by g_t_j - 05-03-2016, 07:07 PM
RE: Heat sink required for Pine64? - by Beryllium - 05-03-2016, 07:54 PM
RE: Heat sink required for Pine64? - by g_t_j - 05-04-2016, 07:22 AM
RE: Heat sink required for Pine64? - by rahlquist - 05-04-2016, 08:02 AM
RE: Heat sink required for Pine64? - by Beryllium - 05-04-2016, 05:32 PM
Heat sink required for Pine64? - by Leoncito81 - 05-03-2016, 09:20 PM
RE: Heat sink required for Pine64? - by tkaiser - 05-04-2016, 02:49 AM
RE: Heat sink required for Pine64? - by Pepe - 05-28-2016, 05:18 AM
RE: Heat sink required for Pine64? - by g_t_j - 05-28-2016, 05:27 AM
  When Will the Heat Sinks From Pine be Available? Bob123456789 3 5,041 05-05-2016, 12:07 AM
