Heat sink required for Pine64?
I just wanted to check if it is suggested to use a heat sink/fan for my Pine64.
I was using my Pine64 for about 2 hours last night to watch some videos in Kodi and after that, just out of curiosity, I touched the A64 chip and it was super hot, I did not measure the temperature but i felt it was hot enough to melt the circuit if i watch videos for a longer duration.
Specifics:-
Pine 64 - 2GB
OS - Android, 04/28/2016 image flashed using Phoenix card.
Outside temp - 21 degree Celsius
Other - No overclocking
Heat sink required for Pine64? - by pinea64.edison - 05-03-2016, 10:38 AM
RE: Heat sink required for Pine64? - by Beryllium - 05-03-2016, 05:13 PM
RE: Heat sink required for Pine64? - by g_t_j - 05-03-2016, 06:00 PM
RE: Heat sink required for Pine64? - by Beryllium - 05-03-2016, 06:31 PM
RE: Heat sink required for Pine64? - by g_t_j - 05-28-2016, 05:00 AM
RE: Heat sink required for Pine64? - by g_t_j - 05-03-2016, 07:07 PM
RE: Heat sink required for Pine64? - by Beryllium - 05-03-2016, 07:54 PM
RE: Heat sink required for Pine64? - by g_t_j - 05-04-2016, 07:22 AM
RE: Heat sink required for Pine64? - by rahlquist - 05-04-2016, 08:02 AM
RE: Heat sink required for Pine64? - by Beryllium - 05-04-2016, 05:32 PM
Heat sink required for Pine64? - by Leoncito81 - 05-03-2016, 09:20 PM
RE: Heat sink required for Pine64? - by tkaiser - 05-04-2016, 02:49 AM
RE: Heat sink required for Pine64? - by Pepe - 05-28-2016, 05:18 AM
RE: Heat sink required for Pine64? - by g_t_j - 05-28-2016, 05:27 AM
  When Will the Heat Sinks From Pine be Available? Bob123456789 3 5,060 05-05-2016, 12:07 AM
