IR add-on availability
(05-21-2016, 12:30 AM)Calli Wrote:
(05-20-2016, 11:09 AM)tllim Wrote:
(05-20-2016, 10:26 AM)Calli Wrote:
(05-04-2016, 10:42 AM)tllim Wrote:
(05-04-2016, 09:05 AM)rahlquist Wrote: Anyone care to therorize if a TSOP4838 will work in place of the TSSP58038 that tllim is using?
Pine IR sensor according to tllim http://www.vishay.com/docs/82479/tssp58038.pdf
TSOP4838 http://www.vishay.com/docs/82459/tsop48.pdf
The S and O difference in the part number means S=Sensor or O=IR reciever
They both have the same base 38khz frequency (last two digits of the part numbers)
Their electrical characteristics seem very similar. Their package shape seems to be the largest difference? Anyone?
Both works.
I buyed this sensor http://www.ebay.es/itm/TSOP4838-Sensor-I...Swv0tVNiUa and this remote http://www.amazon.es/dp/B00O00SEBI .
Didn't works at Android, what's the matter? It's the correct remote?
The remote is not correct but sensor should be OK.
This remote only works on MX player, it has different command set then Pine64. For Pine64 command, please refer to Pine64 wiki page.
Thank you!
This one it's the same http://www.ebay.es/itm/New-Android-TV-BO...SwxYxUv6eG
will work?
Unless the command code is identical, it will not works even looks the same shape.
IR add-on availability - by mpjf01 - 05-02-2016, 07:36 PM
RE: IR add-on availability - by tllim - 05-03-2016, 08:52 AM
RE: IR add-on availability - by rahlquist - 05-04-2016, 09:05 AM
RE: IR add-on availability - by tllim - 05-04-2016, 10:42 AM
RE: IR add-on availability - by Calli - 05-20-2016, 10:26 AM
RE: IR add-on availability - by tllim - 05-20-2016, 11:09 AM
RE: IR add-on availability - by Calli - 05-21-2016, 12:30 AM
RE: IR add-on availability - by tllim - 05-21-2016, 08:35 AM
RE: IR add-on availability - by Calli - 05-22-2016, 09:00 AM
RE: IR add-on availability - by tllim - 05-22-2016, 09:55 AM
