Pine A64+ Gigabit issue...
If you scale from 1000MBit to 10Mbit and everything works, doesn't Clock/Interrupt seem like a more likely cause of the problems people are seeing than power? If you change your CPU clock governor to performance and that affects your Ethernet performance, doesn't that suggest the Ethernet is on a governed clock? Are we using the right clock for the job? Is the clock configured correctly?
I will note on Gigabit settings an 80% packet loss on the local network at a packet rate of 1/s which is enough to reduce any TCP to a standstill.
Pine A64+ Gigabit issue... - by rhkean - 05-02-2016, 07:29 AM
RE: Pine A64+ Gigabit issue... - by rahlquist - 05-02-2016, 09:01 AM
RE: Pine A64+ Gigabit issue... - by rhkean - 05-02-2016, 09:12 AM
RE: Pine A64+ Gigabit issue... - by tkaiser - 05-02-2016, 09:25 AM
RE: Pine A64+ Gigabit issue... - by rhkean - 05-02-2016, 10:02 PM
RE: Pine A64+ Gigabit issue... - by tkaiser - 05-02-2016, 11:57 PM
RE: Pine A64+ Gigabit issue... - by rhkean - 05-03-2016, 10:31 PM
RE: Pine A64+ Gigabit issue... - by tkaiser - 05-04-2016, 01:46 AM
RE: Pine A64+ Gigabit issue... - by rahlquist - 05-02-2016, 09:22 AM
RE: Pine A64+ Gigabit issue... - by rhkean - 05-03-2016, 06:56 AM
RE: Pine A64+ Gigabit issue... - by tkaiser - 05-03-2016, 07:15 AM
RE: Pine A64+ Gigabit issue... - by tkaiser - 05-04-2016, 03:01 AM
RE: Pine A64+ Gigabit issue... - by rhkean - 05-04-2016, 06:38 AM
RE: Pine A64+ Gigabit issue... - by tkaiser - 05-04-2016, 07:00 AM
Pine A64+ Gigabit issue... - by Faye - 05-04-2016, 10:18 AM
RE: Pine A64+ Gigabit issue... - by tkaiser - 05-04-2016, 10:46 AM
Pine A64+ Gigabit issue... - by Faye - 05-04-2016, 06:32 PM
RE: Pine A64+ Gigabit issue... - by rahlquist - 05-04-2016, 08:25 PM
RE: Pine A64+ Gigabit issue... - by rhkean - 05-04-2016, 09:13 PM
RE: Pine A64+ Gigabit issue... - by rahlquist - 05-05-2016, 06:33 AM
RE: Pine A64+ Gigabit issue... - by rhkean - 05-05-2016, 07:25 AM
RE: Pine A64+ Gigabit issue... - by tkaiser - 05-05-2016, 07:33 AM
RE: Pine A64+ Gigabit issue... - by rhkean - 05-05-2016, 01:17 PM
RE: Pine A64+ Gigabit issue... - by frewind - 05-05-2016, 04:29 PM
RE: Pine A64+ Gigabit issue... - by frewind - 05-05-2016, 04:30 PM
RE: Pine A64+ Gigabit issue... - by frewind - 05-05-2016, 04:54 PM
RE: Pine A64+ Gigabit issue... - by amc2012 - 06-10-2016, 10:01 PM
RE: Pine A64+ Gigabit issue... - by waldo - 07-13-2016, 02:13 PM
RE: Pine A64+ Gigabit issue... - by rhkean - 07-13-2016, 03:11 PM
RE: Pine A64+ Gigabit issue... - by waldo - 07-13-2016, 06:51 PM
RE: Pine A64+ Gigabit issue... - by amc2012 - 07-14-2016, 10:57 AM
RE: Pine A64+ Gigabit issue... - by waldo - 07-14-2016, 03:02 PM
RE: Pine A64+ Gigabit issue... - by niall - 07-17-2016, 07:32 AM
  Pine A64+ mainline mipi-dsi Learnincurve 3 6,697 01-12-2021, 07:36 AM
Last Post: Learnincurve
  DietPi OS for PINE A64 MichaIng 0 9,260 12-15-2020, 06:11 AM
Last Post: MichaIng
  Fedora 32/CentOS 8 Pine A64+ Images wideawake 2 5,554 10-02-2020, 11:38 AM
Last Post: mathiraj
  LibreELEC(KODI) for Pine A64 (+) pineadmin 6 15,898 05-02-2020, 10:29 AM
Last Post: aaronmarsh632
  Lakka-nightlies for Pine A64 (and H64) roel 11 19,561 04-23-2020, 12:55 AM
Last Post: roel
  Read DHT22 on Pine A64 ayufan 3 6,699 01-19-2020, 02:51 PM
Last Post: {-DesT-}
  Centos 7 for Pine A64 Luke 2 6,147 05-28-2019, 12:18 AM
Last Post: pineadmin
  NEMS Linux for Pine A64 (+) Luke 1 5,193 05-09-2019, 05:42 PM
  Pine Board using linux stuck during boot sequence ktaragorn 4 8,389 03-30-2019, 06:48 AM
Last Post: ktaragorn
  motionEyeOS (PINE A64(+)) pineadmin 4 12,082 11-09-2018, 03:25 AM
