External DAC
#78
(11-18-2016, 08:42 PM)cr2016 Wrote: @mrv,
Any chance to know what you did try/test?  Wink
Yes, just the basics
1) Does it boot
2) Do I have ethernet issues
3) Are the controls working as normal (e.g can I see it as DLNA renderer, is the webUI available and responsive)
4) Is music playing, from the library and from webradio
5) Can I add sources, does it connect normally
6) Can I control it, can adjust volume, play on the various sources (headphone, hdmi etc)
Have not tried to add an USB stick for wifi
possible issue I had was that the Factory reset was hanging. Seems that sdcard was corrupt or something. Did not repeat, so i'm not sure if it was due to a bug, filesystem full or sd corruption.
Anyway, I found it much more responsive than my RPI (v1b) volumio setup. (which is no surprise)
So now finally I have some good use of my 2nd pine board. (I consider pine useless for all things that have hdmi out as it is not working on any of my monitors or tv screens in a stable way. If the ethernet speed is fine, headless use seems okay with the pines)
External DAC - by kresten_ - 01-03-2016, 11:18 AM
RE: External DAC - by tllim - 01-03-2016, 11:43 AM
RE: External DAC - by stephen fleming - 02-01-2016, 07:10 PM
RE: External DAC - by tllim - 02-01-2016, 08:26 PM
RE: External DAC - by hazerty - 01-03-2016, 12:00 PM
RE: External DAC - by tllim - 01-03-2016, 12:14 PM
RE: External DAC - by StefanB - 01-29-2016, 07:01 PM
RE: External DAC - by tllim - 01-29-2016, 11:09 PM
RE: External DAC - by barichon21 - 01-30-2016, 03:11 AM
RE: External DAC - by tllim - 01-30-2016, 11:31 AM
RE: External DAC - by Danton - 01-30-2016, 03:24 AM
RE: External DAC - by Danton - 02-01-2016, 10:36 AM
RE: External DAC - by taros - 02-01-2016, 10:39 AM
RE: External DAC - by tllim - 02-01-2016, 04:35 PM
RE: External DAC - by DeepBlu - 02-12-2016, 02:21 AM
RE: External DAC - by joe - 02-12-2016, 03:10 AM
RE: External DAC - by tllim - 02-12-2016, 09:56 PM
RE: External DAC - by aphex0 - 02-12-2016, 10:33 PM
RE: External DAC - by joe - 02-20-2016, 02:43 AM
RE: External DAC - by tllim - 02-21-2016, 09:08 PM
External DAC - by Zoidiano0 - 02-20-2016, 05:16 PM
RE: External DAC - by Zoidiano0 - 03-10-2016, 04:56 PM
RE: External DAC - by tllim - 03-10-2016, 05:25 PM
RE: External DAC - by Zoidiano0 - 03-10-2016, 09:22 PM
RE: External DAC - by gbjensen - 03-12-2016, 01:25 PM
RE: External DAC - by Zoidiano0 - 03-12-2016, 01:38 PM
RE: External DAC - by gbjensen - 03-12-2016, 03:56 PM
RE: External DAC - by xaled - 04-12-2016, 06:41 AM
RE: External DAC - by rosswesleyporter - 04-17-2016, 06:48 PM
RE: External DAC - by Zoidiano0 - 04-17-2016, 09:09 PM
RE: External DAC - by kidrock - 05-27-2016, 02:25 PM
RE: External DAC - by tllim - 05-27-2016, 03:02 PM
RE: External DAC - by gbjensen - 06-23-2016, 03:47 AM
RE: External DAC - by joe - 07-31-2016, 04:11 AM
RE: External DAC - by tllim - 08-01-2016, 01:57 PM
RE: External DAC - by CareyCorbin - 09-28-2016, 12:09 PM
RE: External DAC - by tllim - 10-02-2016, 02:20 PM
RE: External DAC - by Danton - 10-05-2016, 12:39 AM
RE: External DAC - by tllim - 10-07-2016, 04:33 PM
RE: External DAC - by entropy attenuation - 10-05-2016, 01:14 AM
RE: External DAC - by mstraa - 10-25-2016, 06:21 AM
RE: External DAC - by tllim - 10-25-2016, 08:07 PM
RE: External DAC - by cr2016 - 11-03-2016, 01:39 AM
RE: External DAC - by cr2016 - 11-04-2016, 04:57 PM
RE: External DAC - by tllim - 11-06-2016, 09:44 PM
RE: External DAC - by gkkpch - 11-05-2016, 12:54 PM
RE: External DAC - by mrv - 11-13-2016, 03:48 PM
RE: External DAC - by Luke - 11-13-2016, 06:40 PM
RE: External DAC - by cr2016 - 11-05-2016, 03:31 PM
RE: External DAC - by gkkpch - 11-05-2016, 06:27 PM
RE: External DAC - by tllim - 11-06-2016, 09:45 PM
RE: External DAC - by cr2016 - 11-09-2016, 04:24 AM
RE: External DAC - by gkkpch - 11-14-2016, 12:34 AM
RE: External DAC - by gkkpch - 11-17-2016, 05:10 PM
RE: External DAC - by Luke - 11-17-2016, 05:19 PM
RE: External DAC - by gkkpch - 11-17-2016, 06:56 PM
RE: External DAC - by mrv - 11-18-2016, 12:51 PM
RE: External DAC - by cr2016 - 11-18-2016, 08:42 PM
RE: External DAC - by mrv - 11-20-2016, 01:22 PM
RE: External DAC - by aarturo - 11-19-2016, 02:29 AM
RE: External DAC - by gkkpch - 11-19-2016, 12:29 PM
RE: External DAC - by aarturo - 11-19-2016, 05:06 PM
RE: External DAC - by gkkpch - 11-20-2016, 07:59 AM
RE: External DAC - by joe - 11-20-2016, 09:45 AM
RE: External DAC - by entropy attenuation - 11-20-2016, 04:27 AM
RE: External DAC - by cr2016 - 11-20-2016, 06:19 PM
RE: External DAC - by mrv - 12-03-2016, 04:51 AM
RE: External DAC - by gkkpch - 12-03-2016, 07:04 AM
RE: External DAC - by gkkpch - 11-21-2016, 02:31 AM
RE: External DAC - by gkkpch - 11-21-2016, 12:27 PM
RE: External DAC - by entropy attenuation - 11-21-2016, 11:52 PM
RE: External DAC - by gkkpch - 11-22-2016, 12:22 AM
RE: External DAC - by Bookingo - 12-02-2016, 12:10 PM
RE: External DAC - by gkkpch - 01-19-2017, 02:31 PM
RE: External DAC - by tllim - 01-20-2017, 08:13 PM
RE: External DAC - by gkkpch - 01-22-2017, 01:05 PM
RE: External DAC - by gkkpch - 01-26-2017, 01:37 AM
RE: External DAC - by Luke - 01-26-2017, 05:49 AM
RE: External DAC - by gkkpch - 01-26-2017, 10:42 AM
RE: External DAC - by Luke - 01-26-2017, 12:12 PM
RE: External DAC - by Myszaks - 01-26-2017, 01:10 PM
RE: External DAC - by gkkpch - 01-26-2017, 01:47 PM
RE: External DAC - by aarturo - 01-28-2017, 12:49 AM
RE: External DAC - by gkkpch - 02-07-2017, 04:59 PM
RE: External DAC - by Luke - 02-07-2017, 05:53 PM
RE: External DAC - by joe - 02-09-2017, 06:52 AM
RE: External DAC - by tllim - 02-12-2017, 10:47 PM
RE: External DAC - by mbt28 - 02-08-2017, 08:04 AM
RE: External DAC - by tllim - 02-12-2017, 10:48 PM
RE: External DAC - by mbt28 - 02-09-2017, 12:07 PM
RE: External DAC - by ealltech - 02-28-2017, 12:48 AM
RE: External DAC - by MarkHaysHarris777 - 02-28-2017, 02:04 AM
RE: External DAC - by pfeerick - 02-28-2017, 04:47 AM
RE: External DAC - by gkkpch - 03-06-2017, 05:14 PM
RE: External DAC - by gkkpch - 03-07-2017, 12:42 PM
RE: External DAC - by cr2016 - 03-09-2017, 04:02 AM
RE: External DAC - by gkkpch - 03-09-2017, 04:15 AM
RE: External DAC - by cr2016 - 03-09-2017, 05:05 AM
RE: External DAC - by joe - 03-19-2017, 04:23 AM
RE: External DAC - by Luke - 03-19-2017, 10:30 AM
RE: External DAC - by Irmscher - 03-23-2017, 01:31 PM
RE: External DAC - by Luke - 03-23-2017, 01:47 PM
RE: External DAC - by stuckinhere - 03-29-2017, 09:01 PM
RE: External DAC - by Luke - 03-30-2017, 06:32 AM
RE: External DAC - by cr2016 - 04-10-2017, 03:34 AM
RE: External DAC - by Luke - 04-10-2017, 05:19 AM
RE: External DAC - by gkkpch - 04-16-2017, 11:20 AM
RE: External DAC - by Luke - 04-18-2017, 06:06 AM
RE: External DAC - by cr2016 - 06-24-2017, 03:20 AM
RE: External DAC - by joe - 06-24-2017, 10:29 AM
RE: External DAC - by gkkpch - 06-25-2017, 11:07 AM
RE: External DAC - by xalius - 06-24-2017, 07:02 AM
RE: External DAC - by xalius - 06-25-2017, 04:25 PM
RE: External DAC - by gkkpch - 06-26-2017, 12:25 AM
RE: External DAC - by cr2016 - 06-26-2017, 04:48 AM
RE: External DAC - by Luke - 07-02-2017, 07:57 AM
RE: External DAC - by gkkpch - 07-02-2017, 10:09 AM
RE: External DAC - by Luke - 07-03-2017, 05:34 AM
RE: External DAC - by james.irwin - 07-09-2017, 04:26 AM
RE: External DAC - by joe - 09-25-2017, 12:07 PM
RE: External DAC - by cr2016 - 07-03-2017, 03:46 AM
RE: External DAC - by kjez - 09-11-2017, 12:04 AM
RE: External DAC - by gkkpch - 09-25-2017, 02:08 PM
RE: External DAC - by Luke - 09-26-2017, 08:59 AM
RE: External DAC - by gkkpch - 09-26-2017, 11:56 AM
RE: External DAC - by gkkpch - 11-06-2017, 07:33 AM
RE: External DAC - by Luke - 11-06-2017, 07:53 AM
RE: External DAC - by gkkpch - 11-06-2017, 10:11 AM
RE: External DAC - by Luke - 11-06-2017, 10:50 AM
RE: External DAC - by joe - 11-06-2017, 09:27 PM
RE: External DAC - by gkkpch - 11-07-2017, 01:08 AM
RE: External DAC - by joe - 11-07-2017, 03:46 AM
RE: External DAC - by Luke - 11-07-2017, 05:23 AM
RE: External DAC - by gkkpch - 11-07-2017, 09:48 AM
RE: External DAC - by joe - 11-07-2017, 10:09 AM
RE: External DAC - by mat1 - 11-07-2017, 01:29 AM
RE: External DAC - by gkkpch - 11-07-2017, 01:57 AM
RE: External DAC - by mat1 - 11-07-2017, 02:04 AM
RE: External DAC - by Luke - 11-07-2017, 11:29 AM
RE: External DAC - by gkkpch - 11-07-2017, 11:35 AM
RE: External DAC - by gkkpch - 11-11-2017, 01:46 PM
RE: External DAC - by joe - 11-12-2017, 06:04 AM
RE: External DAC - by gkkpch - 11-12-2017, 01:04 PM
RE: External DAC - by Luke - 11-12-2017, 03:59 PM
RE: External DAC - by mat1 - 11-13-2017, 04:52 AM
RE: External DAC - by Luke - 11-13-2017, 05:12 AM
RE: External DAC - by gkkpch - 11-14-2017, 11:55 AM
RE: External DAC - by joe - 11-13-2017, 05:15 AM
RE: External DAC - by mat1 - 11-13-2017, 05:24 AM
RE: External DAC - by joe - 11-13-2017, 05:27 AM
RE: External DAC - by mat1 - 11-13-2017, 05:57 AM
RE: External DAC - by Luke - 11-13-2017, 06:04 AM
RE: External DAC - by joe - 11-13-2017, 06:48 AM
RE: External DAC - by Luke - 11-13-2017, 06:50 AM
RE: External DAC - by joe - 11-13-2017, 09:47 AM
RE: External DAC - by Luke - 11-13-2017, 03:31 PM
RE: External DAC - by joe - 11-13-2017, 07:59 PM
RE: External DAC - by Luke - 11-14-2017, 12:04 PM
RE: External DAC - by gkkpch - 11-14-2017, 12:05 PM
RE: External DAC - by Luke - 11-14-2017, 04:51 PM
RE: External DAC - by joe - 11-19-2017, 06:59 AM
RE: External DAC - by gkkpch - 11-24-2017, 03:50 PM
RE: External DAC - by joe - 11-28-2017, 03:29 AM
RE: External DAC - by gkkpch - 03-17-2018, 04:56 AM
RE: External DAC - by gkkpch - 03-30-2018, 10:22 AM
RE: External DAC - by tllim - 04-02-2018, 06:24 PM
  Popping on SPDIF - External DAC mjgoode 3 9,185 05-14-2019, 11:12 AM
Last Post: TrisWood
