Fn + F keys screwy for F9, F10, F11 and F12
Bug
ANSI PBP, keyboard/touchpad firmware update applied. Using the Fn key with the keys on the top row, Esc through F8 seems fine:
Esc: Calls up the shutdown menu
F1: Brightness down
F2: Brightness up
F3: Seems to be the same as the Pine key? Presumably that's fine
F4: Mute
F5: Volume down
F6: Volume up
F7: Disables the trackpad
F8: Insert
However, F9 onwards seems wrong, both in what keycodes xev reports and in observed behaviour:
F9: Label says Print Screen, but instead Num_Lock
F10: Label says NumLK, but instead Scroll_Lock
F11: Label says ScrLK, but instead Pause
F12: Label says Pause Break, but instead Num_Lock
Other blue-label keys (ie. the numberpad keys, delete, home/end, page up/down) all seem to be mapped as expected.
Fn + F keys screwy for F9, F10, F11 and F12 - by keithzg - 01-10-2020, 06:15 PM
  Some Keys No Longer Working pietenpol 0 1,765 06-05-2021, 05:39 PM
Last Post: pietenpol
  Some keyboard keys not working oddsocks 10 10,909 04-20-2021, 08:33 AM
Last Post: dsimic
  Keyboard - Some keys not working Christoph.Krn 1 3,292 08-27-2020, 07:15 PM
Last Post: rdmarsh
  Some keys have stopped working wsgts 1 2,896 04-07-2020, 06:24 AM
Last Post: wsgts
  Center touchpad under typing keys in future versions? Damon 3 5,113 03-21-2020, 02:01 PM
Last Post: Dendrocalamus64
  Keyboard keys rearrangable? User 16030 6 6,927 01-14-2020, 09:30 AM
Last Post: jackhumbert
