How do I save my time settings?
(01-12-2020, 02:39 AM)NigelT Wrote: MrDitchy, if bash tells you "command not found" when you try and run dpkg-reconfigure, it's probably because you are trying to run it as a non-root user.
When you enter a command without specifying where it is, the shell looks in the directories specified in the PATH variable to find it.
You'll notice the root account has directories in it's PATH that are not typically present in a non-root account, and the dpkg-reconfigure command is in one of those directories, hence bash doesn't find it and says "command not found".
In your case simply use sudo (it will Switch User to root before DOing the command, invoke the command, then switch back after the command has run).
$ sudo dpkg-reconfigure tzdata
Thanks for that. It has worked.
I would like to thank both of you for taking the time out to help me. I have been a little late with responding, because for some reason my email decided to hide the posts in my spam folder and then not notify me. Thanks again
How do I save my time settings? - by MrDitchy - 01-04-2020, 01:13 AM
RE: How do I save my time settings? - by MrDitchy - 01-04-2020, 02:06 PM
RE: How do I save my time settings? - by MrDitchy - 01-05-2020, 01:06 PM
RE: How do I save my time settings? - by MrDitchy - 01-12-2020, 01:00 AM
RE: How do I save my time settings? - by NigelT - 01-12-2020, 01:47 AM
RE: How do I save my time settings? - by NigelT - 01-12-2020, 02:39 AM
RE: How do I save my time settings? - by MrDitchy - 01-17-2020, 09:48 PM
Question Graphical Glitch in Settings sciolus 4 5,322 03-12-2021, 08:23 AM
Last Post: sciolus
  Network settings, where to find the config files? hvdkooij 1 2,885 11-20-2020, 02:47 PM
Last Post: xyzzy
  Saving ALSA settings? Baslow 9 9,772 09-04-2020, 09:05 AM
Last Post: brzegorz
  Very long lag time using SSH via Wifi in factory Debian OS Redbeard 4 5,213 02-16-2020, 10:19 AM
  how I "fixed" Chromium crashing on accessing settings richfm 7 8,401 12-17-2019, 04:35 AM
Last Post: andybleaden@gmail.com
