Flashing not working
I am using OpenOCD with Raspberry Pi 4 to flash the PineTime dev kit. It worked for a day properly. I tested bluetooth and LCD example code using Zephyr RTOS. But all of the sudden it stopped working.
What I noticed when connecting SWD wires the LCD backlight turns on and also when putting the back cover (no SWD connection) the motor starts vibrating. Is it short-circuit? What should I check? Investing the OpenOCD debug log (below) it seems chip is not getting acknowledged.
Open On-Chip Debugger 0.10.0+dev-00985-g2dc88e14 (2019-12-25-21:43)
User : 13 9 options.c:63 configuration_output_handler(): debug_level: 4
User : 14 9 options.c:63 configuration_output_handler():
Debug: 15 9 options.c:187 add_default_dirs(): bindir=/usr/local/bin
Debug: 16 9 options.c:188 add_default_dirs(): pkgdatadir=/usr/local/share/openocd
Debug: 17 9 options.c:189 add_default_dirs(): exepath=/home/pi/openocd/src
Debug: 18 9 options.c:190 add_default_dirs(): bin2data=../share/openocd
Debug: 19 9 configuration.c:42 add_script_search_dir(): adding /root/.openocd
Debug: 20 9 configuration.c:42 add_script_search_dir(): adding /home/pi/openocd/src/../share/openocd/site
Debug: 21 9 configuration.c:42 add_script_search_dir(): adding /home/pi/openocd/src/../share/openocd/scripts
Debug: 22 10 configuration.c:97 find_file(): found /home/pi/swd-pi.ocd
Debug: 23 10 command.c:143 script_debug(): command - interface interface bcm2835gpio
Debug: 25 10 command.c:354 register_command_handler(): registering 'bcm2835gpio_jtag_nums'...
Debug: 26 10 command.c:354 register_command_handler(): registering 'bcm2835gpio_tck_num'...
Debug: 27 10 command.c:354 register_command_handler(): registering 'bcm2835gpio_tms_num'...
Debug: 28 10 command.c:354 register_command_handler(): registering 'bcm2835gpio_tdo_num'...
Debug: 29 10 command.c:354 register_command_handler(): registering 'bcm2835gpio_tdi_num'...
Debug: 30 10 command.c:354 register_command_handler(): registering 'bcm2835gpio_swd_nums'...
Debug: 31 10 command.c:354 register_command_handler(): registering 'bcm2835gpio_swclk_num'...
Debug: 32 10 command.c:354 register_command_handler(): registering 'bcm2835gpio_swdio_num'...
Debug: 33 10 command.c:354 register_command_handler(): registering 'bcm2835gpio_srst_num'...
Debug: 34 10 command.c:354 register_command_handler(): registering 'bcm2835gpio_trst_num'...
Debug: 35 11 command.c:354 register_command_handler(): registering 'bcm2835gpio_speed_coeffs'...
Debug: 36 11 command.c:354 register_command_handler(): registering 'bcm2835gpio_peripheral_base'...
Debug: 37 11 command.c:143 script_debug(): command - bcm2835gpio_peripheral_base bcm2835gpio_peripheral_base 0x3F000000
Debug: 39 11 command.c:143 script_debug(): command - bcm2835gpio_speed_coeffs bcm2835gpio_speed_coeffs 194938 48
Debug: 41 11 command.c:143 script_debug(): command - bcm2835gpio_swd_nums bcm2835gpio_swd_nums 20 21
Debug: 43 11 command.c:143 script_debug(): command - bcm2835gpio_srst_num bcm2835gpio_srst_num 18
Debug: 45 11 command.c:143 script_debug(): command - transport transport select swd
Debug: 46 11 command.c:354 register_command_handler(): registering 'swd'...
Debug: 47 11 bitbang.c:402 bitbang_swd_init(): bitbang_swd_init
Debug: 48 11 configuration.c:97 find_file(): found /home/pi/openocd/tcl/target/nrf52.cfg
Debug: 49 12 configuration.c:97 find_file(): found /home/pi/openocd/tcl/target/swj-dp.tcl
Debug: 50 12 command.c:143 script_debug(): command - transport transport select
Debug: 51 12 command.c:143 script_debug(): command - transport transport select
Debug: 52 12 command.c:143 script_debug(): command - transport transport select
Debug: 53 13 command.c:143 script_debug(): command - transport transport select
Debug: 54 13 command.c:143 script_debug(): command - swd swd newdap nrf52 cpu -expected-id 0x2ba01477
Debug: 55 13 tcl.c:567 jim_newtap_cmd(): Creating New Tap, Chip: nrf52, Tap: cpu, Dotted: nrf52.cpu, 2 params
Debug: 56 13 core.c:1373 jtag_tap_init(): Created Tap: nrf52.cpu @ abs position 0, irlen 0, capture: 0x0 mask: 0x0
Debug: 57 13 command.c:143 script_debug(): command - dap dap create nrf52.dap -chain-position nrf52.cpu
Debug: 58 13 command.c:354 register_command_handler(): registering 'nrf52.dap'...
Debug: 59 13 command.c:354 register_command_handler(): registering 'nrf52.dap'...
Debug: 60 13 command.c:354 register_command_handler(): registering 'nrf52.dap'...
Debug: 61 13 command.c:354 register_command_handler(): registering 'nrf52.dap'...
Debug: 62 13 command.c:354 register_command_handler(): registering 'nrf52.dap'...
Debug: 63 13 command.c:354 register_command_handler(): registering 'nrf52.dap'...
Debug: 64 13 command.c:354 register_command_handler(): registering 'nrf52.dap'...
Debug: 65 13 command.c:354 register_command_handler(): registering 'nrf52.dap'...
Debug: 66 13 command.c:354 register_command_handler(): registering 'nrf52.dap'...
Debug: 67 13 command.c:143 script_debug(): command - target target create nrf52.cpu cortex_m -dap nrf52.dap
Debug: 68 14 command.c:354 register_command_handler(): registering 'arm'...
Debug: 69 14 command.c:354 register_command_handler(): registering 'arm'...
Debug: 70 14 command.c:354 register_command_handler(): registering 'arm'...
Debug: 71 14 command.c:354 register_command_handler(): registering 'arm'...
Debug: 72 14 command.c:354 register_command_handler(): registering 'arm'...
Debug: 73 14 command.c:354 register_command_handler(): registering 'arm'...
Debug: 74 14 command.c:354 register_command_handler(): registering 'arm'...
Debug: 75 14 command.c:354 register_command_handler(): registering 'arm'...
Debug: 76 14 command.c:354 register_command_handler(): registering 'arm'...
Debug: 77 14 command.c:354 register_command_handler(): registering 'tpiu'...
Debug: 78 14 command.c:354 register_command_handler(): registering 'itm'...
Debug: 79 14 command.c:354 register_command_handler(): registering 'itm'...
Debug: 80 14 command.c:354 register_command_handler(): registering 'cortex_m'...
Debug: 81 14 command.c:354 register_command_handler(): registering 'cortex_m'...
Debug: 82 14 command.c:354 register_command_handler(): registering 'cortex_m'...
Debug: 83 14 command.c:354 register_command_handler(): registering 'nrf52.cpu'...
Debug: 84 14 command.c:354 register_command_handler(): registering 'nrf52.cpu'...
Debug: 85 14 command.c:354 register_command_handler(): registering 'nrf52.cpu'...
Debug: 86 14 command.c:354 register_command_handler(): registering 'nrf52.cpu'...
Debug: 87 14 command.c:354 register_command_handler(): registering 'nrf52.cpu'...
Debug: 88 14 command.c:354 register_command_handler(): registering 'nrf52.cpu'...
Debug: 89 14 command.c:354 register_command_handler(): registering 'nrf52.cpu'...
Debug: 90 14 command.c:354 register_command_handler(): registering 'nrf52.cpu'...
Debug: 91 15 command.c:354 register_command_handler(): registering 'nrf52.cpu'...
Debug: 92 15 command.c:354 register_command_handler(): registering 'nrf52.cpu'...
Debug: 93 15 command.c:354 register_command_handler(): registering 'nrf52.cpu'...
Debug: 94 15 command.c:354 register_command_handler(): registering 'nrf52.cpu'...
Debug: 95 15 command.c:354 register_command_handler(): registering 'nrf52.cpu'...
Debug: 96 15 command.c:354 register_command_handler(): registering 'nrf52.cpu'...
Debug: 97 15 command.c:354 register_command_handler(): registering 'nrf52.cpu'...
Debug: 98 15 command.c:354 register_command_handler(): registering 'nrf52.cpu'...
Debug: 99 15 command.c:354 register_command_handler(): registering 'nrf52.cpu'...
Debug: 100 15 command.c:354 register_command_handler(): registering 'nrf52.cpu'...
Debug: 101 15 command.c:354 register_command_handler(): registering 'nrf52.cpu'...
Debug: 102 15 command.c:354 register_command_handler(): registering 'nrf52.cpu'...
Debug: 103 15 command.c:354 register_command_handler(): registering 'nrf52.cpu'...
Debug: 104 15 command.c:354 register_command_handler(): registering 'nrf52.cpu'...
Debug: 105 15 command.c:354 register_command_handler(): registering 'nrf52.cpu'...
Debug: 106 15 command.c:354 register_command_handler(): registering 'nrf52.cpu'...
Debug: 107 15 command.c:354 register_command_handler(): registering 'nrf52.cpu'...
Debug: 108 15 command.c:354 register_command_handler(): registering 'nrf52.cpu'...
Debug: 109 15 command.c:354 register_command_handler(): registering 'nrf52.cpu'...
Debug: 110 15 command.c:354 register_command_handler(): registering 'nrf52.cpu'...
Debug: 111 15 command.c:354 register_command_handler(): registering 'nrf52.cpu'...
Debug: 112 15 command.c:354 register_command_handler(): registering 'nrf52.cpu'...
Debug: 113 15 command.c:354 register_command_handler(): registering 'nrf52.cpu'...
Debug: 114 15 command.c:354 register_command_handler(): registering 'nrf52.cpu'...
Debug: 115 15 command.c:354 register_command_handler(): registering 'nrf52.cpu'...
Debug: 116 15 command.c:354 register_command_handler(): registering 'nrf52.cpu'...
Debug: 117 15 command.c:354 register_command_handler(): registering 'nrf52.cpu'...
Debug: 118 15 command.c:354 register_command_handler(): registering 'nrf52.cpu'...
Debug: 119 15 command.c:354 register_command_handler(): registering 'nrf52.cpu'...
Debug: 120 16 command.c:354 register_command_handler(): registering 'nrf52.cpu'...
Debug: 121 16 command.c:354 register_command_handler(): registering 'nrf52.cpu'...
Debug: 122 16 command.c:354 register_command_handler(): registering 'nrf52.cpu'...
Debug: 123 16 command.c:354 register_command_handler(): registering 'nrf52.cpu'...
Debug: 124 16 command.c:354 register_command_handler(): registering 'nrf52.cpu'...
Debug: 125 16 command.c:143 script_debug(): command - adapter_khz adapter_khz 1000
Debug: 127 16 core.c:1705 jtag_config_khz(): handle jtag khz
Debug: 128 16 core.c:1668 adapter_khz_to_speed(): convert khz to interface specific speed value
Debug: 129 16 core.c:1668 adapter_khz_to_speed(): convert khz to interface specific speed value
Debug: 130 16 command.c:143 script_debug(): command - nrf52.cpu nrf52.cpu configure -work-area-phys 0x20000000 -work-area-size 0x4000 -work-area-backup 0
Debug: 131 16 target.c:1961 target_free_all_working_areas_restore(): freeing all working areas
Debug: 132 16 target.c:1961 target_free_all_working_areas_restore(): freeing all working areas
Debug: 133 16 target.c:1961 target_free_all_working_areas_restore(): freeing all working areas
Debug: 134 16 command.c:143 script_debug(): command - transport transport select
Debug: 135 16 command.c:143 script_debug(): command - cortex_m cortex_m reset_config sysresetreq
Debug: 137 16 command.c:143 script_debug(): command - flash flash bank nrf52.flash nrf5 0x00000000 0 1 1 nrf52.cpu
Debug: 139 16 command.c:354 register_command_handler(): registering 'nrf5'...
Debug: 140 16 command.c:354 register_command_handler(): registering 'nrf5'...
Debug: 141 17 command.c:354 register_command_handler(): registering 'nrf51'...
Debug: 142 17 command.c:354 register_command_handler(): registering 'nrf51'...
Debug: 143 17 tcl.c:1156 handle_flash_bank_command(): 'nrf5' driver usage field missing
Debug: 144 17 command.c:143 script_debug(): command - flash flash bank nrf52.uicr nrf5 0x10001000 0 1 1 nrf52.cpu
Debug: 146 17 command.c:376 register_command(): command 'nrf5' is already registered in '<global>' context
Debug: 147 17 command.c:376 register_command(): command 'mass_erase' is already registered in 'nrf5' context
Debug: 148 17 command.c:376 register_command(): command 'info' is already registered in 'nrf5' context
Debug: 149 17 command.c:376 register_command(): command 'nrf51' is already registered in '<global>' context
Debug: 150 17 command.c:376 register_command(): command 'mass_erase' is already registered in 'nrf51' context
Debug: 151 17 command.c:376 register_command(): command 'info' is already registered in 'nrf51' context
Debug: 152 17 tcl.c:1156 handle_flash_bank_command(): 'nrf5' driver usage field missing
Debug: 153 17 command.c:143 script_debug(): command - reset_config reset_config srst_only srst_nogate
Debug: 155 17 command.c:143 script_debug(): command - adapter_nsrst_delay adapter_nsrst_delay 100
Debug: 157 17 command.c:143 script_debug(): command - adapter_nsrst_assert_width adapter_nsrst_assert_width 100
Debug: 159 17 command.c:143 script_debug(): command - init init
Debug: 161 17 command.c:143 script_debug(): command - target target init
Debug: 163 17 command.c:143 script_debug(): command - target target names
Debug: 164 18 command.c:143 script_debug(): command - nrf52.cpu nrf52.cpu cget -event gdb-flash-erase-start
Debug: 165 18 command.c:143 script_debug(): command - nrf52.cpu nrf52.cpu configure -event gdb-flash-erase-start reset init
Debug: 166 18 command.c:143 script_debug(): command - nrf52.cpu nrf52.cpu cget -event gdb-flash-write-end
Debug: 167 18 command.c:143 script_debug(): command - nrf52.cpu nrf52.cpu configure -event gdb-flash-write-end reset halt
Debug: 168 18 command.c:143 script_debug(): command - nrf52.cpu nrf52.cpu cget -event gdb-attach
Debug: 169 18 command.c:143 script_debug(): command - nrf52.cpu nrf52.cpu configure -event gdb-attach halt
Debug: 170 18 target.c:1423 handle_target_init_command(): Initializing targets...
Debug: 171 18 semihosting_common.c:97 semihosting_common_init():
Debug: 172 18 command.c:354 register_command_handler(): registering 'target_request'...
Debug: 173 18 command.c:354 register_command_handler(): registering 'trace'...
Debug: 174 18 command.c:354 register_command_handler(): registering 'trace'...
Debug: 175 18 command.c:354 register_command_handler(): registering 'fast_load_image'...
Debug: 176 18 command.c:354 register_command_handler(): registering 'fast_load'...
Debug: 177 18 command.c:354 register_command_handler(): registering 'profile'...
Debug: 178 18 command.c:354 register_command_handler(): registering 'virt2phys'...
Debug: 179 19 command.c:354 register_command_handler(): registering 'reg'...
Debug: 180 19 command.c:354 register_command_handler(): registering 'poll'...
Debug: 181 19 command.c:354 register_command_handler(): registering 'wait_halt'...
Debug: 182 19 command.c:354 register_command_handler(): registering 'halt'...
Debug: 183 19 command.c:354 register_command_handler(): registering 'resume'...
Debug: 184 19 command.c:354 register_command_handler(): registering 'reset'...
Debug: 185 19 command.c:354 register_command_handler(): registering 'soft_reset_halt'...
Debug: 186 19 command.c:354 register_command_handler(): registering 'step'...
Debug: 187 19 command.c:354 register_command_handler(): registering 'mdd'...
Debug: 188 19 command.c:354 register_command_handler(): registering 'mdw'...
Debug: 189 19 command.c:354 register_command_handler(): registering 'mdh'...
Debug: 190 19 command.c:354 register_command_handler(): registering 'mdb'...
Debug: 191 19 command.c:354 register_command_handler(): registering 'mwd'...
Debug: 192 19 command.c:354 register_command_handler(): registering 'mww'...
Debug: 193 19 command.c:354 register_command_handler(): registering 'mwh'...
Debug: 194 19 command.c:354 register_command_handler(): registering 'mwb'...
Debug: 195 19 command.c:354 register_command_handler(): registering 'bp'...
Debug: 196 19 command.c:354 register_command_handler(): registering 'rbp'...
Debug: 197 19 command.c:354 register_command_handler(): registering 'wp'...
Debug: 198 19 command.c:354 register_command_handler(): registering 'rwp'...
Debug: 199 19 command.c:354 register_command_handler(): registering 'load_image'...
Debug: 200 19 command.c:354 register_command_handler(): registering 'dump_image'...
Debug: 201 19 command.c:354 register_command_handler(): registering 'verify_image_checksum'...
Debug: 202 19 command.c:354 register_command_handler(): registering 'verify_image'...
Debug: 203 20 command.c:354 register_command_handler(): registering 'test_image'...
Debug: 204 20 command.c:354 register_command_handler(): registering 'reset_nag'...
Debug: 205 20 command.c:354 register_command_handler(): registering 'ps'...
Debug: 206 20 command.c:354 register_command_handler(): registering 'test_mem_access'...
Info : 207 20 bcm2835gpio.c:450 bcm2835gpio_init(): BCM2835 GPIO JTAG/SWD bitbang driver
Info : 208 20 bcm2835gpio.c:458 bcm2835gpio_init(): SWD only mode enabled (specify tck, tms, tdi and tdo gpios to add JTAG mode)
Debug: 209 20 bcm2835gpio.c:525 bcm2835gpio_init(): saved pinmux settings: tck 0 tms 0 tdi 0 tdo 0 trst 0 srst 4
Debug: 210 20 bitbang.c:457 bitbang_switch_to_swd(): bitbang_switch_to_swd
Debug: 211 20 bitbang.c:409 bitbang_exchange(): bitbang_exchange
Debug: 212 20 core.c:1668 adapter_khz_to_speed(): convert khz to interface specific speed value
Debug: 213 20 core.c:1672 adapter_khz_to_speed(): have interface set up
Debug: 214 20 core.c:1668 adapter_khz_to_speed(): convert khz to interface specific speed value
Debug: 215 20 core.c:1672 adapter_khz_to_speed(): have interface set up
Info : 216 20 core.c:1450 adapter_init(): clock speed 1004 kHz
Debug: 217 20 openocd.c:141 handle_init_command(): Debug Adapter init complete
Debug: 218 20 command.c:143 script_debug(): command - transport transport init
Debug: 220 20 transport.c:239 handle_transport_init(): handle_transport_init
Debug: 221 20 command.c:143 script_debug(): command - dap dap init
Debug: 223 20 arm_dap.c:106 dap_init_all(): Initializing all DAPs ...
Debug: 224 20 bitbang.c:432 bitbang_swd_switch_seq(): bitbang_swd_switch_seq
Debug: 225 20 bitbang.c:440 bitbang_swd_switch_seq(): JTAG-to-SWD
Debug: 226 20 bitbang.c:409 bitbang_exchange(): bitbang_exchange
Debug: 227 21 bitbang.c:469 bitbang_swd_read_reg(): bitbang_swd_read_reg
Debug: 228 21 bitbang.c:409 bitbang_exchange(): bitbang_exchange
Debug: 229 21 bitbang.c:409 bitbang_exchange(): bitbang_exchange
Debug: 230 21 bitbang.c:496 bitbang_swd_read_reg(): JUNK DP read reg 0 = ffffffff
Debug: 231 21 bitbang.c:519 bitbang_swd_read_reg(): No valid acknowledge: ack=7
Debug: 232 21 bitbang.c:528 bitbang_swd_write_reg(): bitbang_swd_write_reg
Debug: 233 21 bitbang.c:532 bitbang_swd_write_reg(): Skip bitbang_swd_write_reg because queued_retval=7
Debug: 234 21 bitbang.c:580 bitbang_swd_run_queue(): bitbang_swd_run_queue
Debug: 235 21 bitbang.c:409 bitbang_exchange(): bitbang_exchange
Debug: 236 21 bitbang.c:587 bitbang_swd_run_queue(): SWD queue return value: 07
Debug: 237 21 command.c:629 run_command(): Command 'dap init' failed with error code 7
User : 238 21 command.c:694 command_run_line():
Debug: 239 21 command.c:629 run_command(): Command 'init' failed with error code -4
User : 240 22 command.c:694 command_run_line():
Debug: 241 22 target.c:1961 target_free_all_working_areas_restore(): freeing all working areas
Debug: 242 22 bitbang.c:432 bitbang_swd_switch_seq(): bitbang_swd_switch_seq
Debug: 243 22 bitbang.c:444 bitbang_swd_switch_seq(): SWD-to-JTAG
Debug: 244 22 bitbang.c:409 bitbang_exchange(): bitbang_exchange
Debug: 245 22 bitbang.c:580 bitbang_swd_run_queue(): bitbang_swd_run_queue
Debug: 246 22 bitbang.c:409 bitbang_exchange(): bitbang_exchange
Debug: 247 22 bitbang.c:587 bitbang_swd_run_queue(): SWD queue return value: 00
Flashing not working - by yokonav - 12-28-2019, 06:49 AM
RE: Flashing not working - by yokonav - 01-15-2020, 12:08 AM
RE: Flashing not working - by cjmakes - 02-23-2020, 03:05 AM
RE: Flashing not working - by wibble - 02-24-2020, 06:36 AM
RE: Flashing not working - by cjmakes - 02-28-2020, 10:15 PM
RE: Flashing not working - by danielt - 05-06-2020, 07:31 AM
RE: Flashing not working - by jkl - 05-25-2020, 08:46 AM
RE: Flashing not working - by danielt - 05-26-2020, 04:10 AM
RE: Flashing not working - by jkl - 03-05-2020, 07:50 AM
RE: Flashing not working - by jkl - 03-06-2020, 03:12 AM
RE: Flashing not working - by fld - 03-06-2020, 10:41 AM
RE: Flashing not working - by jkl - 05-05-2020, 11:14 AM
RE: Flashing not working - by slembcke - 03-04-2021, 03:24 PM
RE: Flashing not working - by danielt - 03-11-2021, 04:39 AM
  No Luck flashing WaspOS MadHatter 0 426 12-11-2023, 01:19 AM
Last Post: MadHatter
  Accelerometer stopped working victor9 15 10,227 02-13-2023, 05:05 PM
Last Post: Luri
  Screen stopped working properly pcfreak9000 3 1,733 01-18-2023, 04:28 PM
  PineTime Touch Screen Stopped Working BlunderingBushcraft 3 2,908 07-30-2022, 04:19 PM
Last Post: headgr
  can anyone suggest their working Linux bluetooth USB dongles to connect to Pinetime? jahway603 4 2,708 07-27-2022, 07:38 PM
Last Post: jahway603
  Flashing with RF Connect ronaldheld 12 7,337 04-28-2022, 04:27 AM
Last Post: ITCactus
Question [question] how to restore PineTime to a factory state after flashing non-OTA/directly ITCactus 2 2,516 04-11-2022, 05:03 AM
Last Post: ITCactus
Question Which companion apps work best for flashing firmware and pairing/syncing w/ Pinetime? danimations 0 1,540 03-28-2022, 08:22 PM
Last Post: danimations
Sad Account not working - missing permissions? Droidian 0 1,292 09-24-2021, 05:30 AM
Last Post: Droidian
  Working with Fito Track Glockdoc 2 2,167 09-04-2021, 10:23 AM
Last Post: barray
