PBP Displayed Clock-Calendar Drops Hour Setting On Reboot.
(01-22-2020, 10:16 AM)jackhumbert Wrote: I was able to fix this in the default image by setting the timezone in the command line:
timedatectl set-timezone Zone/SubZone
You can list all of them:
timedatectl list-timezones
and just check it:
timedatectl
My /etc/adjtime was correct (adjusted via the GUI in the date options), but this command was still showing the UTC as my timezone. After a couple of reboots, it seems to be holding, and /etc/localtime is correct as well (I'm not sure what it was before).
Thanks Jack... Worked very well, was always going back to GMT!
crocky
RE: PBP Displayed Clock-Calendar Drops Hour Setting On Reboot. - by crocky - 01-23-2020, 12:31 AM
  nvme drive disappears after about an hour of uptime codebreaker 25 32,647 02-09-2021, 11:32 PM
Last Post: dsimic
  Reboot, and halt and boot, are not the same regivanx 0 1,984 09-14-2020, 02:20 PM
Last Post: regivanx
  Memory clock speed: 800MHz vs 1600MHz? (NM, RK3399 won't run >800MHz DDR) Syonyk 4 7,301 06-26-2020, 07:22 PM
Last Post: Syonyk
