Alternative plug-end for PBP wall wart?
(03-09-2020, 07:33 AM)tophneal Wrote: If the barrel connector of the Dell power supply is different than that of the PBP, you can probably look for an step up/down adapter if you know the OD/ID of the other barrel. The PBP's barrel size can be found in the wiki.
From what I have seen the barrel connector (3.5mm OD, 1.35mm ID) is also known as a "Type-H" connector.
The most common DC extension leads use the bigger "Arduino/laptop" (5.5mm OD, 2.1mm ID) connectors.
You can get big-to-small barrel adapters and small-to-big but that would add a lot of connections between charger and Pinebook Sad
RE: Alternative plug-end for PBP wall wart? - by neilman - 03-09-2020, 12:47 PM
  Steps for Installing Alternative OSes in 2022 jazzhands 8 2,971 11-15-2022, 09:39 AM
  OBS Studio or alternative on Pinebook Pro? charlespine 4 6,452 09-26-2020, 07:59 AM
Last Post: khan
  powerup upon plug event robt 5 5,811 07-02-2020, 04:37 PM
Last Post: robt
  Alternative to the screws? MIchael 10 13,063 03-12-2020, 08:46 AM
Last Post: ab1jx
