Nextcloudpi SD card fills up.
This is the second time i've had this issue running nextcloudpi on my rock64.  It runs fine for about a month and then my SD card shows that it's full and I have no room left.  This prevents my nextcloud server from running correctly and I can't connect.
Nextcloudpi SD card fills up. - by default_user8 - 11-20-2019, 11:13 PM
RE: Nextcloudpi SD card fills up. - by evilbunny - 11-21-2019, 12:40 AM
RE: Nextcloudpi SD card fills up. - by evilbunny - 11-21-2019, 08:11 PM
RE: Nextcloudpi SD card fills up. - by evilbunny - 11-23-2019, 10:48 PM
RE: Nextcloudpi SD card fills up. - by evilbunny - 11-24-2019, 07:20 PM
RE: Nextcloudpi SD card fills up. - by evilbunny - 11-25-2019, 10:41 PM
RE: Nextcloudpi SD card fills up. - by evilbunny - 12-02-2019, 06:35 PM
  Buildroot 2021.08 not booting from SD card jimmy 1 2,032 11-08-2021, 02:25 AM
Last Post: hunderteins
  NextCloudPi image for Rock64, NC version 13.0.2. nachoparker 11 23,524 03-15-2021, 02:59 PM
Last Post: kiriakos
  Tutorial How to write a image in the eMMc card without USB adaptor or serial cable gedas07 2 3,842 08-29-2018, 10:08 AM
Last Post: gedas07
  If you've messed up your eMMC Card - Solved gregb49 11 16,493 07-11-2018, 02:08 PM
Last Post: gregb49
  Help with a MicroSD card problem on Rock 64 Jakr 6 8,064 08-13-2017, 03:31 PM
Last Post: jl_678
