LAN/NIC problem
#64
(09-10-2016, 05:00 PM)clarkss12 Wrote: I did cut the wires on a cat6 cable per his instructions, but did not work for me.
You may have cut the wrong wire.
... the white wires with the trace coloring are difficult to see ( some vendors are worse than others ) and of course you should have good lighting.  My first guess is that the wrong wire was cut, and the other guess is that your cat6 cable might be defective ( one of the green or orange wires might have a break in it ).
On my cable I actually pulled the wires from their sheath. I cut the blue and brown pairs and physically pulled the wires from the cable, and resealed the cable with shrink wrap; worked fine.
It pretty much has to work; unless you cut the wrong wire.
LAN/NIC problem - by xrez - 04-28-2016, 04:17 PM
RE: LAN/NIC problem - by wanthalf - 08-05-2016, 04:07 PM
RE: LAN/NIC problem - by waldo - 08-05-2016, 06:51 PM
RE: LAN/NIC problem - by MarkHaysHarris777 - 08-05-2016, 10:09 PM
RE: LAN/NIC problem - by wanthalf - 08-06-2016, 04:21 PM
RE: LAN/NIC problem - by MarkHaysHarris777 - 08-06-2016, 05:11 PM
RE: LAN/NIC problem - by wanthalf - 08-08-2016, 02:52 PM
RE: LAN/NIC problem - by MarkHaysHarris777 - 08-09-2016, 12:30 PM
RE: LAN/NIC problem - by wanthalf - 08-09-2016, 04:46 PM
RE: LAN/NIC problem - by MarkHaysHarris777 - 08-09-2016, 05:04 PM
RE: LAN/NIC problem - by pfeerick - 08-29-2016, 10:54 PM
RE: LAN/NIC problem - by jandvs - 08-29-2016, 10:26 PM
RE: LAN/NIC problem - by MarkHaysHarris777 - 08-29-2016, 10:49 PM
RE: LAN/NIC problem - by jandvs - 08-31-2016, 06:03 PM
RE: LAN/NIC problem - by MarkHaysHarris777 - 08-31-2016, 08:14 PM
RE: LAN/NIC problem - by jandvs - 08-31-2016, 08:49 PM
RE: LAN/NIC problem - by MarkHaysHarris777 - 08-31-2016, 09:15 PM
RE: LAN/NIC problem - by tkaiser - 09-01-2016, 12:24 AM
RE: LAN/NIC problem - by MarkHaysHarris777 - 09-01-2016, 05:16 AM
RE: LAN/NIC problem - by pfeerick - 09-01-2016, 06:05 AM
RE: LAN/NIC problem - by MarkHaysHarris777 - 09-01-2016, 07:28 AM
RE: LAN/NIC problem - by amc2012 - 09-01-2016, 08:45 AM
RE: LAN/NIC problem - by jandvs - 09-01-2016, 09:21 AM
RE: LAN/NIC problem - by tkaiser - 09-01-2016, 05:29 AM
RE: LAN/NIC problem - by jandvs - 09-01-2016, 07:28 AM
RE: LAN/NIC problem - by MarkHaysHarris777 - 09-01-2016, 07:32 AM
RE: LAN/NIC problem - by cdslashetc - 09-01-2016, 05:54 PM
RE: LAN/NIC problem - by MarkHaysHarris777 - 09-01-2016, 06:01 PM
RE: LAN/NIC problem - by amc2012 - 09-02-2016, 12:25 AM
RE: LAN/NIC problem - by cdslashetc - 09-04-2016, 04:33 AM
RE: LAN/NIC problem - by jandvs - 09-02-2016, 07:37 AM
RE: LAN/NIC problem - by amc2012 - 09-02-2016, 08:23 AM
RE: LAN/NIC problem - by MarkHaysHarris777 - 09-02-2016, 08:35 AM
RE: LAN/NIC problem - by longsleep - 09-02-2016, 09:03 AM
RE: LAN/NIC problem - by amc2012 - 09-02-2016, 10:21 AM
RE: LAN/NIC problem - by jandvs - 09-02-2016, 11:29 AM
RE: LAN/NIC problem - by longsleep - 09-02-2016, 12:41 PM
RE: LAN/NIC problem - by cdslashetc - 09-02-2016, 01:32 PM
RE: LAN/NIC problem - by jandvs - 09-03-2016, 10:23 AM
RE: LAN/NIC problem - by jandvs - 09-06-2016, 06:57 AM
RE: LAN/NIC problem - by jandvs - 09-06-2016, 03:18 PM
RE: LAN/NIC problem - by MarkHaysHarris777 - 09-06-2016, 03:36 PM
RE: LAN/NIC problem - by jandvs - 09-07-2016, 12:53 PM
RE: LAN/NIC problem - by MarkHaysHarris777 - 09-07-2016, 01:36 PM
RE: LAN/NIC problem - by androsch - 09-07-2016, 02:36 PM
RE: LAN/NIC problem - by MarkHaysHarris777 - 09-07-2016, 03:54 PM
RE: LAN/NIC problem - by jandvs - 09-08-2016, 08:38 AM
RE: LAN/NIC problem - by androsch - 09-08-2016, 11:11 AM
RE: LAN/NIC problem - by MarkHaysHarris777 - 09-08-2016, 11:41 AM
RE: LAN/NIC problem - by pfeerick - 09-08-2016, 09:33 PM
RE: LAN/NIC problem - by MarkHaysHarris777 - 09-09-2016, 05:42 AM
RE: LAN/NIC problem - by waldo - 09-09-2016, 05:56 AM
RE: LAN/NIC problem - by MarkHaysHarris777 - 09-09-2016, 06:06 AM
RE: LAN/NIC problem - by jandvs - 09-08-2016, 01:40 PM
RE: LAN/NIC problem - by MarkHaysHarris777 - 09-08-2016, 02:24 PM
RE: LAN/NIC problem - by tllim - 09-08-2016, 08:24 PM
RE: LAN/NIC problem - by clarkss12 - 09-09-2016, 05:41 PM
RE: LAN/NIC problem - by clarkss12 - 09-09-2016, 09:19 PM
RE: LAN/NIC problem - by MarkHaysHarris777 - 09-10-2016, 09:07 AM
RE: LAN/NIC problem - by waldo - 09-10-2016, 11:39 AM
RE: LAN/NIC problem - by clarkss12 - 09-10-2016, 01:07 PM
RE: LAN/NIC problem - by MarkHaysHarris777 - 09-10-2016, 01:15 PM
RE: LAN/NIC problem - by clarkss12 - 09-10-2016, 05:00 PM
RE: LAN/NIC problem - by MarkHaysHarris777 - 09-10-2016, 05:04 PM
RE: LAN/NIC problem - by clarkss12 - 09-11-2016, 07:28 AM
RE: LAN/NIC problem - by cdslashetc - 09-11-2016, 08:05 AM
RE: LAN/NIC problem - by clarkss12 - 09-11-2016, 09:25 AM
RE: LAN/NIC problem - by clarkss12 - 09-11-2016, 10:47 AM
RE: LAN/NIC problem - by jandvs - 09-12-2016, 10:47 AM
RE: LAN/NIC problem - by MarkHaysHarris777 - 09-12-2016, 10:57 AM
RE: LAN/NIC problem - by tkaiser - 09-12-2016, 11:30 AM
RE: LAN/NIC problem - by MarkHaysHarris777 - 09-12-2016, 09:16 PM
RE: LAN/NIC problem - by jandvs - 09-14-2016, 08:42 AM
RE: LAN/NIC problem - by clarkss12 - 09-12-2016, 01:30 PM
RE: LAN/NIC problem - by tkaiser - 09-12-2016, 02:04 PM
RE: LAN/NIC problem - by clarkss12 - 09-12-2016, 02:24 PM
RE: LAN/NIC problem - by tkaiser - 09-12-2016, 02:36 PM
RE: LAN/NIC problem - by clarkss12 - 09-12-2016, 02:46 PM
RE: LAN/NIC problem - by MarkHaysHarris777 - 09-12-2016, 05:25 PM
RE: LAN/NIC problem - by clarkss12 - 09-12-2016, 07:00 PM
RE: LAN/NIC problem - by MarkHaysHarris777 - 09-12-2016, 07:04 PM
RE: LAN/NIC problem - by amc2012 - 09-12-2016, 07:12 PM
RE: LAN/NIC problem - by MarkHaysHarris777 - 09-12-2016, 07:29 PM
RE: LAN/NIC problem - by tkaiser - 09-13-2016, 12:17 AM
RE: LAN/NIC problem - by MarkHaysHarris777 - 09-13-2016, 12:24 AM
RE: LAN/NIC problem - by amc2012 - 09-13-2016, 12:37 AM
RE: LAN/NIC problem - by MarkHaysHarris777 - 09-13-2016, 12:43 AM
RE: LAN/NIC problem - by MarkHaysHarris777 - 09-13-2016, 01:44 AM
RE: LAN/NIC problem - by tllim - 09-13-2016, 09:42 AM
RE: LAN/NIC problem - by amc2012 - 09-13-2016, 09:44 AM
RE: LAN/NIC problem - by MarkHaysHarris777 - 09-13-2016, 10:00 AM
RE: LAN/NIC problem - by pfeerick - 09-13-2016, 07:00 PM
RE: LAN/NIC problem - by tkaiser - 09-13-2016, 10:22 AM
RE: LAN/NIC problem - by waldo - 09-13-2016, 10:44 AM
RE: LAN/NIC problem - by MarkHaysHarris777 - 09-13-2016, 10:48 AM
RE: LAN/NIC problem - by tkaiser - 09-13-2016, 10:56 AM
RE: LAN/NIC problem - by MarkHaysHarris777 - 09-13-2016, 11:08 AM
RE: LAN/NIC problem - by tllim - 09-13-2016, 06:11 PM
RE: LAN/NIC problem - by amc2012 - 09-13-2016, 11:16 AM
RE: LAN/NIC problem - by tkaiser - 09-14-2016, 09:36 AM
RE: LAN/NIC problem - by amc2012 - 09-14-2016, 10:06 AM
RE: LAN/NIC problem - by MarkHaysHarris777 - 09-14-2016, 10:18 AM
RE: LAN/NIC problem - by tkaiser - 09-14-2016, 10:37 AM
RE: LAN/NIC problem - by MarkHaysHarris777 - 09-14-2016, 08:15 PM
RE: LAN/NIC problem - by tkaiser - 09-15-2016, 01:39 AM
RE: LAN/NIC problem - by MarkHaysHarris777 - 09-15-2016, 01:48 AM
RE: LAN/NIC problem - by jandvs - 09-15-2016, 07:16 AM
RE: LAN/NIC problem - by tkaiser - 09-15-2016, 08:26 AM
RE: LAN/NIC problem - by tllim - 09-14-2016, 05:31 PM
RE: LAN/NIC problem - by DonFL - 09-13-2016, 10:08 AM
RE: LAN/NIC problem - by MarkHaysHarris777 - 09-13-2016, 10:15 AM
RE: LAN/NIC problem - by tkaiser - 09-13-2016, 10:43 AM
RE: LAN/NIC problem - by tllim - 09-13-2016, 05:52 PM
RE: LAN/NIC problem - by tkaiser - 09-14-2016, 07:17 AM
RE: LAN/NIC problem - by MarkHaysHarris777 - 09-13-2016, 10:33 AM
RE: LAN/NIC problem - by martinayotte - 09-13-2016, 10:52 AM
RE: LAN/NIC problem - by tllim - 09-13-2016, 06:04 PM
RE: LAN/NIC problem - by clarkss12 - 09-13-2016, 01:47 PM
RE: LAN/NIC problem - by MarkHaysHarris777 - 09-13-2016, 03:40 PM
RE: LAN/NIC problem - by tllim - 09-13-2016, 06:06 PM
RE: LAN/NIC problem - by stepw - 09-14-2016, 06:45 PM
RE: LAN/NIC problem - by tkaiser - 09-13-2016, 05:31 PM
RE: LAN/NIC problem - by waldo - 09-13-2016, 05:38 PM
RE: LAN/NIC problem - by cdslashetc - 09-14-2016, 08:14 AM
RE: LAN/NIC problem - by androsch - 09-14-2016, 10:22 AM
RE: LAN/NIC problem - by cdslashetc - 09-14-2016, 10:44 AM
RE: LAN/NIC problem - by tkaiser - 09-14-2016, 12:11 PM
RE: LAN/NIC problem - by amc2012 - 09-14-2016, 12:48 PM
RE: LAN/NIC problem - by tkaiser - 09-14-2016, 03:36 PM
RE: LAN/NIC problem - by waldo - 09-14-2016, 04:34 PM
RE: LAN/NIC problem - by tkaiser - 09-14-2016, 04:49 PM
RE: LAN/NIC problem - by tkaiser - 09-15-2016, 12:01 AM
RE: LAN/NIC problem - by pfeerick - 09-15-2016, 12:58 AM
RE: LAN/NIC problem - by tkaiser - 09-15-2016, 01:49 AM
RE: LAN/NIC problem - by pfeerick - 09-15-2016, 02:23 AM
RE: LAN/NIC problem - by MarkHaysHarris777 - 09-15-2016, 01:31 AM
RE: LAN/NIC problem - by tkaiser - 09-15-2016, 06:38 AM
RE: LAN/NIC problem - by MarkHaysHarris777 - 09-15-2016, 02:48 PM
RE: LAN/NIC problem - by amc2012 - 09-15-2016, 03:46 PM
RE: LAN/NIC problem - by tkaiser - 09-15-2016, 04:36 PM
RE: LAN/NIC problem - by pfeerick - 09-15-2016, 07:18 PM
RE: LAN/NIC problem - by tkaiser - 09-15-2016, 11:49 PM
RE: LAN/NIC problem - by MarkHaysHarris777 - 09-16-2016, 12:34 AM
RE: LAN/NIC problem - by tkaiser - 09-16-2016, 01:21 AM
RE: LAN/NIC problem - by amc2012 - 09-16-2016, 08:29 AM
RE: LAN/NIC problem - by tkaiser - 09-16-2016, 09:48 AM
RE: LAN/NIC problem - by amc2012 - 09-16-2016, 10:00 AM
RE: LAN/NIC problem - by tkaiser - 09-16-2016, 10:44 AM
RE: LAN/NIC problem - by pfeerick - 09-17-2016, 03:36 AM
RE: LAN/NIC problem - by tkaiser - 09-17-2016, 05:27 AM
RE: LAN/NIC problem - by stepw - 09-18-2016, 09:16 PM
RE: LAN/NIC problem - by tkaiser - 09-18-2016, 11:11 PM
RE: LAN/NIC problem - by tkaiser - 09-19-2016, 08:53 AM
RE: LAN/NIC problem - by clarkss12 - 09-20-2016, 04:50 AM
RE: LAN/NIC problem - by Terra854 - 09-20-2016, 04:55 AM
RE: LAN/NIC problem - by clarkss12 - 09-20-2016, 05:13 AM
RE: LAN/NIC problem - by tkaiser - 09-20-2016, 05:17 AM
RE: LAN/NIC problem - by clarkss12 - 09-20-2016, 06:05 AM
RE: LAN/NIC problem - by tkaiser - 09-20-2016, 07:11 AM
RE: LAN/NIC problem - by clarkss12 - 09-20-2016, 07:23 AM
RE: LAN/NIC problem - by MarkHaysHarris777 - 09-20-2016, 07:37 AM
RE: LAN/NIC problem - by tkaiser - 09-20-2016, 08:10 AM
RE: LAN/NIC problem - by clarkss12 - 09-20-2016, 07:43 AM
RE: LAN/NIC problem - by clarkss12 - 09-20-2016, 08:25 AM
RE: LAN/NIC problem - by amc2012 - 09-20-2016, 03:22 PM
RE: LAN/NIC problem - by tkaiser - 09-20-2016, 03:49 PM
RE: LAN/NIC problem - by tkaiser - 09-20-2016, 08:35 AM
RE: LAN/NIC problem - by clarkss12 - 09-20-2016, 08:51 AM
RE: LAN/NIC problem - by clarkss12 - 09-20-2016, 04:57 PM
RE: LAN/NIC problem - by tkaiser - 09-21-2016, 12:55 AM
RE: LAN/NIC problem - by MarkHaysHarris777 - 09-21-2016, 01:29 AM
RE: LAN/NIC problem - by kflorek46 - 09-21-2016, 05:02 PM
RE: LAN/NIC problem - by tkaiser - 09-22-2016, 12:52 AM
RE: LAN/NIC problem - by waldo - 09-26-2016, 02:58 PM
RE: LAN/NIC problem - by tllim - 09-27-2016, 07:56 PM
RE: LAN/NIC problem - by waldo - 09-28-2016, 01:59 PM
RE: LAN/NIC problem - by amc2012 - 09-29-2016, 03:17 PM
RE: LAN/NIC problem - by waldo - 09-29-2016, 03:33 PM
RE: LAN/NIC problem - by stepw - 09-29-2016, 07:39 PM
RE: LAN/NIC problem - by amc2012 - 09-29-2016, 08:31 PM
RE: LAN/NIC problem - by waldo - 09-30-2016, 09:41 AM
RE: LAN/NIC problem - by jandvs - 10-05-2016, 04:48 PM
RE: LAN/NIC problem - by amc2012 - 10-05-2016, 05:13 PM
RE: LAN/NIC problem - by jandvs - 10-05-2016, 08:27 PM
RE: LAN/NIC problem - by pfeerick - 10-05-2016, 11:17 PM
RE: LAN/NIC problem - by androsch - 10-06-2016, 05:41 AM
RE: LAN/NIC problem - by waldo - 10-27-2016, 11:32 AM
RE: LAN/NIC problem - by tllim - 10-31-2016, 04:28 PM
LAN/NIC problem - by androsch - 11-01-2016, 05:45 AM
RE: LAN/NIC problem - by stepw - 11-01-2016, 09:16 PM
RE: LAN/NIC problem - by tllim - 11-02-2016, 04:43 PM
RE: LAN/NIC problem - by waldo - 11-02-2016, 10:45 AM
RE: LAN/NIC problem - by tllim - 11-02-2016, 05:10 PM
RE: LAN/NIC problem - by tllim - 11-02-2016, 05:12 PM
RE: LAN/NIC problem - by umiddelb - 11-03-2016, 01:43 AM
RE: LAN/NIC problem - by waldo - 11-03-2016, 10:43 AM
RE: LAN/NIC problem - by MarkHaysHarris777 - 11-06-2016, 06:35 AM
RE: LAN/NIC problem - by dkryder - 11-07-2016, 12:23 AM
RE: LAN/NIC problem - by pfeerick - 11-10-2016, 07:46 PM
RE: LAN/NIC problem - by MarkHaysHarris777 - 11-10-2016, 08:57 PM
RE: LAN/NIC problem - by seaniefs - 11-06-2016, 04:49 AM
RE: LAN/NIC problem - by seaniefs - 11-06-2016, 11:44 AM
RE: LAN/NIC problem - by stepw - 11-06-2016, 08:24 PM
RE: LAN/NIC problem - by tllim - 11-06-2016, 09:30 PM
RE: LAN/NIC problem - by Learnincurve - 12-16-2016, 06:32 AM
RE: LAN/NIC problem - by tllim - 12-16-2016, 09:05 PM
RE: LAN/NIC problem - by androsch - 12-17-2016, 01:39 PM
RE: LAN/NIC problem - by DrunkTank - 01-17-2017, 01:55 PM
RE: LAN/NIC problem - by DrunkTank - 01-18-2017, 07:57 PM
RE: LAN/NIC problem - by tllim - 01-20-2017, 02:45 PM
RE: LAN/NIC problem - by DrunkTank - 01-20-2017, 03:31 PM
RE: LAN/NIC problem - by Er0l - 12-20-2016, 01:47 PM
RE: LAN/NIC problem - by HenryD - 12-28-2016, 11:34 AM
RE: LAN/NIC problem - by aegrotatio - 01-03-2017, 10:26 PM
RE: LAN/NIC problem - by ealltech - 02-28-2017, 12:36 AM
RE: LAN/NIC problem - by ubuntuGuy - 06-15-2017, 06:04 PM
RE: LAN/NIC problem - by pfeerick - 06-16-2017, 02:04 AM
RE: LAN/NIC problem - by ubuntuGuy - 06-18-2017, 03:36 PM
