LAN/NIC problem
#62
(09-10-2016, 01:07 PM)clarkss12 Wrote: I did follow the instructions on how to get fast Ethernet to work under Android, but did not work for me.  But obviously, my experiences with my other Android boxes does not apply in this case?????  So, this board is useless for my right now for Android or Remix.  It does play well under Linux, and that is what I have been using with I use it.
Hi clarkss12,  try making a four wire ethernet cable (what people here are calling a hackyfix) where you physically remove the blue and brown pairs from your Cat5 or Cat6 cable leaving intact the two pairs that are orange and green...   the orange and green wires are all that is necessary for 100mb/s comm, and no software 'fix' is necessary.  Make sure you have the right pairs... remove blue, and brown, (all four wires) each color has a solid and a tracer.
The remaining wires will make your eth on remix or android work fine... pins 1,2,3, and 6...  green and orange.
LAN/NIC problem - by xrez - 04-28-2016, 04:17 PM
RE: LAN/NIC problem - by wanthalf - 08-05-2016, 04:07 PM
RE: LAN/NIC problem - by waldo - 08-05-2016, 06:51 PM
RE: LAN/NIC problem - by MarkHaysHarris777 - 08-05-2016, 10:09 PM
RE: LAN/NIC problem - by wanthalf - 08-06-2016, 04:21 PM
RE: LAN/NIC problem - by MarkHaysHarris777 - 08-06-2016, 05:11 PM
RE: LAN/NIC problem - by wanthalf - 08-08-2016, 02:52 PM
RE: LAN/NIC problem - by MarkHaysHarris777 - 08-09-2016, 12:30 PM
RE: LAN/NIC problem - by wanthalf - 08-09-2016, 04:46 PM
RE: LAN/NIC problem - by MarkHaysHarris777 - 08-09-2016, 05:04 PM
RE: LAN/NIC problem - by pfeerick - 08-29-2016, 10:54 PM
RE: LAN/NIC problem - by jandvs - 08-29-2016, 10:26 PM
RE: LAN/NIC problem - by MarkHaysHarris777 - 08-29-2016, 10:49 PM
RE: LAN/NIC problem - by jandvs - 08-31-2016, 06:03 PM
RE: LAN/NIC problem - by MarkHaysHarris777 - 08-31-2016, 08:14 PM
RE: LAN/NIC problem - by jandvs - 08-31-2016, 08:49 PM
RE: LAN/NIC problem - by MarkHaysHarris777 - 08-31-2016, 09:15 PM
RE: LAN/NIC problem - by tkaiser - 09-01-2016, 12:24 AM
RE: LAN/NIC problem - by MarkHaysHarris777 - 09-01-2016, 05:16 AM
RE: LAN/NIC problem - by pfeerick - 09-01-2016, 06:05 AM
RE: LAN/NIC problem - by MarkHaysHarris777 - 09-01-2016, 07:28 AM
RE: LAN/NIC problem - by amc2012 - 09-01-2016, 08:45 AM
RE: LAN/NIC problem - by jandvs - 09-01-2016, 09:21 AM
RE: LAN/NIC problem - by tkaiser - 09-01-2016, 05:29 AM
RE: LAN/NIC problem - by jandvs - 09-01-2016, 07:28 AM
RE: LAN/NIC problem - by MarkHaysHarris777 - 09-01-2016, 07:32 AM
RE: LAN/NIC problem - by cdslashetc - 09-01-2016, 05:54 PM
RE: LAN/NIC problem - by MarkHaysHarris777 - 09-01-2016, 06:01 PM
RE: LAN/NIC problem - by amc2012 - 09-02-2016, 12:25 AM
RE: LAN/NIC problem - by cdslashetc - 09-04-2016, 04:33 AM
RE: LAN/NIC problem - by jandvs - 09-02-2016, 07:37 AM
RE: LAN/NIC problem - by amc2012 - 09-02-2016, 08:23 AM
RE: LAN/NIC problem - by MarkHaysHarris777 - 09-02-2016, 08:35 AM
RE: LAN/NIC problem - by longsleep - 09-02-2016, 09:03 AM
RE: LAN/NIC problem - by amc2012 - 09-02-2016, 10:21 AM
RE: LAN/NIC problem - by jandvs - 09-02-2016, 11:29 AM
RE: LAN/NIC problem - by longsleep - 09-02-2016, 12:41 PM
RE: LAN/NIC problem - by cdslashetc - 09-02-2016, 01:32 PM
RE: LAN/NIC problem - by jandvs - 09-03-2016, 10:23 AM
RE: LAN/NIC problem - by jandvs - 09-06-2016, 06:57 AM
RE: LAN/NIC problem - by jandvs - 09-06-2016, 03:18 PM
RE: LAN/NIC problem - by MarkHaysHarris777 - 09-06-2016, 03:36 PM
RE: LAN/NIC problem - by jandvs - 09-07-2016, 12:53 PM
RE: LAN/NIC problem - by MarkHaysHarris777 - 09-07-2016, 01:36 PM
RE: LAN/NIC problem - by androsch - 09-07-2016, 02:36 PM
RE: LAN/NIC problem - by MarkHaysHarris777 - 09-07-2016, 03:54 PM
RE: LAN/NIC problem - by jandvs - 09-08-2016, 08:38 AM
RE: LAN/NIC problem - by androsch - 09-08-2016, 11:11 AM
RE: LAN/NIC problem - by MarkHaysHarris777 - 09-08-2016, 11:41 AM
RE: LAN/NIC problem - by pfeerick - 09-08-2016, 09:33 PM
RE: LAN/NIC problem - by MarkHaysHarris777 - 09-09-2016, 05:42 AM
RE: LAN/NIC problem - by waldo - 09-09-2016, 05:56 AM
RE: LAN/NIC problem - by MarkHaysHarris777 - 09-09-2016, 06:06 AM
RE: LAN/NIC problem - by jandvs - 09-08-2016, 01:40 PM
RE: LAN/NIC problem - by MarkHaysHarris777 - 09-08-2016, 02:24 PM
RE: LAN/NIC problem - by tllim - 09-08-2016, 08:24 PM
RE: LAN/NIC problem - by clarkss12 - 09-09-2016, 05:41 PM
RE: LAN/NIC problem - by clarkss12 - 09-09-2016, 09:19 PM
RE: LAN/NIC problem - by MarkHaysHarris777 - 09-10-2016, 09:07 AM
RE: LAN/NIC problem - by waldo - 09-10-2016, 11:39 AM
RE: LAN/NIC problem - by clarkss12 - 09-10-2016, 01:07 PM
RE: LAN/NIC problem - by MarkHaysHarris777 - 09-10-2016, 01:15 PM
RE: LAN/NIC problem - by clarkss12 - 09-10-2016, 05:00 PM
RE: LAN/NIC problem - by MarkHaysHarris777 - 09-10-2016, 05:04 PM
RE: LAN/NIC problem - by clarkss12 - 09-11-2016, 07:28 AM
RE: LAN/NIC problem - by cdslashetc - 09-11-2016, 08:05 AM
RE: LAN/NIC problem - by clarkss12 - 09-11-2016, 09:25 AM
RE: LAN/NIC problem - by clarkss12 - 09-11-2016, 10:47 AM
RE: LAN/NIC problem - by jandvs - 09-12-2016, 10:47 AM
RE: LAN/NIC problem - by MarkHaysHarris777 - 09-12-2016, 10:57 AM
RE: LAN/NIC problem - by tkaiser - 09-12-2016, 11:30 AM
RE: LAN/NIC problem - by MarkHaysHarris777 - 09-12-2016, 09:16 PM
RE: LAN/NIC problem - by jandvs - 09-14-2016, 08:42 AM
RE: LAN/NIC problem - by clarkss12 - 09-12-2016, 01:30 PM
RE: LAN/NIC problem - by tkaiser - 09-12-2016, 02:04 PM
RE: LAN/NIC problem - by clarkss12 - 09-12-2016, 02:24 PM
RE: LAN/NIC problem - by tkaiser - 09-12-2016, 02:36 PM
RE: LAN/NIC problem - by clarkss12 - 09-12-2016, 02:46 PM
RE: LAN/NIC problem - by MarkHaysHarris777 - 09-12-2016, 05:25 PM
RE: LAN/NIC problem - by clarkss12 - 09-12-2016, 07:00 PM
RE: LAN/NIC problem - by MarkHaysHarris777 - 09-12-2016, 07:04 PM
RE: LAN/NIC problem - by amc2012 - 09-12-2016, 07:12 PM
RE: LAN/NIC problem - by MarkHaysHarris777 - 09-12-2016, 07:29 PM
RE: LAN/NIC problem - by tkaiser - 09-13-2016, 12:17 AM
RE: LAN/NIC problem - by MarkHaysHarris777 - 09-13-2016, 12:24 AM
RE: LAN/NIC problem - by amc2012 - 09-13-2016, 12:37 AM
RE: LAN/NIC problem - by MarkHaysHarris777 - 09-13-2016, 12:43 AM
RE: LAN/NIC problem - by MarkHaysHarris777 - 09-13-2016, 01:44 AM
RE: LAN/NIC problem - by tllim - 09-13-2016, 09:42 AM
RE: LAN/NIC problem - by amc2012 - 09-13-2016, 09:44 AM
RE: LAN/NIC problem - by MarkHaysHarris777 - 09-13-2016, 10:00 AM
RE: LAN/NIC problem - by pfeerick - 09-13-2016, 07:00 PM
RE: LAN/NIC problem - by tkaiser - 09-13-2016, 10:22 AM
RE: LAN/NIC problem - by waldo - 09-13-2016, 10:44 AM
RE: LAN/NIC problem - by MarkHaysHarris777 - 09-13-2016, 10:48 AM
RE: LAN/NIC problem - by tkaiser - 09-13-2016, 10:56 AM
RE: LAN/NIC problem - by MarkHaysHarris777 - 09-13-2016, 11:08 AM
RE: LAN/NIC problem - by tllim - 09-13-2016, 06:11 PM
RE: LAN/NIC problem - by amc2012 - 09-13-2016, 11:16 AM
RE: LAN/NIC problem - by tkaiser - 09-14-2016, 09:36 AM
RE: LAN/NIC problem - by amc2012 - 09-14-2016, 10:06 AM
RE: LAN/NIC problem - by MarkHaysHarris777 - 09-14-2016, 10:18 AM
RE: LAN/NIC problem - by tkaiser - 09-14-2016, 10:37 AM
RE: LAN/NIC problem - by MarkHaysHarris777 - 09-14-2016, 08:15 PM
RE: LAN/NIC problem - by tkaiser - 09-15-2016, 01:39 AM
RE: LAN/NIC problem - by MarkHaysHarris777 - 09-15-2016, 01:48 AM
RE: LAN/NIC problem - by jandvs - 09-15-2016, 07:16 AM
RE: LAN/NIC problem - by tkaiser - 09-15-2016, 08:26 AM
RE: LAN/NIC problem - by tllim - 09-14-2016, 05:31 PM
RE: LAN/NIC problem - by DonFL - 09-13-2016, 10:08 AM
RE: LAN/NIC problem - by MarkHaysHarris777 - 09-13-2016, 10:15 AM
RE: LAN/NIC problem - by tkaiser - 09-13-2016, 10:43 AM
RE: LAN/NIC problem - by tllim - 09-13-2016, 05:52 PM
RE: LAN/NIC problem - by tkaiser - 09-14-2016, 07:17 AM
RE: LAN/NIC problem - by MarkHaysHarris777 - 09-13-2016, 10:33 AM
RE: LAN/NIC problem - by martinayotte - 09-13-2016, 10:52 AM
RE: LAN/NIC problem - by tllim - 09-13-2016, 06:04 PM
RE: LAN/NIC problem - by clarkss12 - 09-13-2016, 01:47 PM
RE: LAN/NIC problem - by MarkHaysHarris777 - 09-13-2016, 03:40 PM
RE: LAN/NIC problem - by tllim - 09-13-2016, 06:06 PM
RE: LAN/NIC problem - by stepw - 09-14-2016, 06:45 PM
RE: LAN/NIC problem - by tkaiser - 09-13-2016, 05:31 PM
RE: LAN/NIC problem - by waldo - 09-13-2016, 05:38 PM
RE: LAN/NIC problem - by cdslashetc - 09-14-2016, 08:14 AM
RE: LAN/NIC problem - by androsch - 09-14-2016, 10:22 AM
RE: LAN/NIC problem - by cdslashetc - 09-14-2016, 10:44 AM
RE: LAN/NIC problem - by tkaiser - 09-14-2016, 12:11 PM
RE: LAN/NIC problem - by amc2012 - 09-14-2016, 12:48 PM
RE: LAN/NIC problem - by tkaiser - 09-14-2016, 03:36 PM
RE: LAN/NIC problem - by waldo - 09-14-2016, 04:34 PM
RE: LAN/NIC problem - by tkaiser - 09-14-2016, 04:49 PM
RE: LAN/NIC problem - by tkaiser - 09-15-2016, 12:01 AM
RE: LAN/NIC problem - by pfeerick - 09-15-2016, 12:58 AM
RE: LAN/NIC problem - by tkaiser - 09-15-2016, 01:49 AM
RE: LAN/NIC problem - by pfeerick - 09-15-2016, 02:23 AM
RE: LAN/NIC problem - by MarkHaysHarris777 - 09-15-2016, 01:31 AM
RE: LAN/NIC problem - by tkaiser - 09-15-2016, 06:38 AM
RE: LAN/NIC problem - by MarkHaysHarris777 - 09-15-2016, 02:48 PM
RE: LAN/NIC problem - by amc2012 - 09-15-2016, 03:46 PM
RE: LAN/NIC problem - by tkaiser - 09-15-2016, 04:36 PM
RE: LAN/NIC problem - by pfeerick - 09-15-2016, 07:18 PM
RE: LAN/NIC problem - by tkaiser - 09-15-2016, 11:49 PM
RE: LAN/NIC problem - by MarkHaysHarris777 - 09-16-2016, 12:34 AM
RE: LAN/NIC problem - by tkaiser - 09-16-2016, 01:21 AM
RE: LAN/NIC problem - by amc2012 - 09-16-2016, 08:29 AM
RE: LAN/NIC problem - by tkaiser - 09-16-2016, 09:48 AM
RE: LAN/NIC problem - by amc2012 - 09-16-2016, 10:00 AM
RE: LAN/NIC problem - by tkaiser - 09-16-2016, 10:44 AM
RE: LAN/NIC problem - by pfeerick - 09-17-2016, 03:36 AM
RE: LAN/NIC problem - by tkaiser - 09-17-2016, 05:27 AM
RE: LAN/NIC problem - by stepw - 09-18-2016, 09:16 PM
RE: LAN/NIC problem - by tkaiser - 09-18-2016, 11:11 PM
RE: LAN/NIC problem - by tkaiser - 09-19-2016, 08:53 AM
RE: LAN/NIC problem - by clarkss12 - 09-20-2016, 04:50 AM
RE: LAN/NIC problem - by Terra854 - 09-20-2016, 04:55 AM
RE: LAN/NIC problem - by clarkss12 - 09-20-2016, 05:13 AM
RE: LAN/NIC problem - by tkaiser - 09-20-2016, 05:17 AM
RE: LAN/NIC problem - by clarkss12 - 09-20-2016, 06:05 AM
RE: LAN/NIC problem - by tkaiser - 09-20-2016, 07:11 AM
RE: LAN/NIC problem - by clarkss12 - 09-20-2016, 07:23 AM
RE: LAN/NIC problem - by MarkHaysHarris777 - 09-20-2016, 07:37 AM
RE: LAN/NIC problem - by tkaiser - 09-20-2016, 08:10 AM
RE: LAN/NIC problem - by clarkss12 - 09-20-2016, 07:43 AM
RE: LAN/NIC problem - by clarkss12 - 09-20-2016, 08:25 AM
RE: LAN/NIC problem - by amc2012 - 09-20-2016, 03:22 PM
RE: LAN/NIC problem - by tkaiser - 09-20-2016, 03:49 PM
RE: LAN/NIC problem - by tkaiser - 09-20-2016, 08:35 AM
RE: LAN/NIC problem - by clarkss12 - 09-20-2016, 08:51 AM
RE: LAN/NIC problem - by clarkss12 - 09-20-2016, 04:57 PM
RE: LAN/NIC problem - by tkaiser - 09-21-2016, 12:55 AM
RE: LAN/NIC problem - by MarkHaysHarris777 - 09-21-2016, 01:29 AM
RE: LAN/NIC problem - by kflorek46 - 09-21-2016, 05:02 PM
RE: LAN/NIC problem - by tkaiser - 09-22-2016, 12:52 AM
RE: LAN/NIC problem - by waldo - 09-26-2016, 02:58 PM
RE: LAN/NIC problem - by tllim - 09-27-2016, 07:56 PM
RE: LAN/NIC problem - by waldo - 09-28-2016, 01:59 PM
RE: LAN/NIC problem - by amc2012 - 09-29-2016, 03:17 PM
RE: LAN/NIC problem - by waldo - 09-29-2016, 03:33 PM
RE: LAN/NIC problem - by stepw - 09-29-2016, 07:39 PM
RE: LAN/NIC problem - by amc2012 - 09-29-2016, 08:31 PM
RE: LAN/NIC problem - by waldo - 09-30-2016, 09:41 AM
RE: LAN/NIC problem - by jandvs - 10-05-2016, 04:48 PM
RE: LAN/NIC problem - by amc2012 - 10-05-2016, 05:13 PM
RE: LAN/NIC problem - by jandvs - 10-05-2016, 08:27 PM
RE: LAN/NIC problem - by pfeerick - 10-05-2016, 11:17 PM
RE: LAN/NIC problem - by androsch - 10-06-2016, 05:41 AM
RE: LAN/NIC problem - by waldo - 10-27-2016, 11:32 AM
RE: LAN/NIC problem - by tllim - 10-31-2016, 04:28 PM
LAN/NIC problem - by androsch - 11-01-2016, 05:45 AM
RE: LAN/NIC problem - by stepw - 11-01-2016, 09:16 PM
RE: LAN/NIC problem - by tllim - 11-02-2016, 04:43 PM
RE: LAN/NIC problem - by waldo - 11-02-2016, 10:45 AM
RE: LAN/NIC problem - by tllim - 11-02-2016, 05:10 PM
RE: LAN/NIC problem - by tllim - 11-02-2016, 05:12 PM
RE: LAN/NIC problem - by umiddelb - 11-03-2016, 01:43 AM
RE: LAN/NIC problem - by waldo - 11-03-2016, 10:43 AM
RE: LAN/NIC problem - by MarkHaysHarris777 - 11-06-2016, 06:35 AM
RE: LAN/NIC problem - by dkryder - 11-07-2016, 12:23 AM
RE: LAN/NIC problem - by pfeerick - 11-10-2016, 07:46 PM
RE: LAN/NIC problem - by MarkHaysHarris777 - 11-10-2016, 08:57 PM
RE: LAN/NIC problem - by seaniefs - 11-06-2016, 04:49 AM
RE: LAN/NIC problem - by seaniefs - 11-06-2016, 11:44 AM
RE: LAN/NIC problem - by stepw - 11-06-2016, 08:24 PM
RE: LAN/NIC problem - by tllim - 11-06-2016, 09:30 PM
RE: LAN/NIC problem - by Learnincurve - 12-16-2016, 06:32 AM
RE: LAN/NIC problem - by tllim - 12-16-2016, 09:05 PM
RE: LAN/NIC problem - by androsch - 12-17-2016, 01:39 PM
RE: LAN/NIC problem - by DrunkTank - 01-17-2017, 01:55 PM
RE: LAN/NIC problem - by DrunkTank - 01-18-2017, 07:57 PM
RE: LAN/NIC problem - by tllim - 01-20-2017, 02:45 PM
RE: LAN/NIC problem - by DrunkTank - 01-20-2017, 03:31 PM
RE: LAN/NIC problem - by Er0l - 12-20-2016, 01:47 PM
RE: LAN/NIC problem - by HenryD - 12-28-2016, 11:34 AM
RE: LAN/NIC problem - by aegrotatio - 01-03-2017, 10:26 PM
RE: LAN/NIC problem - by ealltech - 02-28-2017, 12:36 AM
RE: LAN/NIC problem - by ubuntuGuy - 06-15-2017, 06:04 PM
RE: LAN/NIC problem - by pfeerick - 06-16-2017, 02:04 AM
RE: LAN/NIC problem - by ubuntuGuy - 06-18-2017, 03:36 PM
