Longer Power Cable
(11-10-2019, 09:51 AM)Tekchip Wrote: The power cable that comes with the device is incredibly short. Nearly useless. It doesn't reach my couch from an outlet so I can't sit on the couch and use the laptop when battery is low while it's charging. I've tried a few different USB-C wall warts and cables and while most can charge the laptop while I'm not using it they can't really push enough power to charge in a reasonable amount of time while in use.
Does anyone have recommendations for either a USB-C wall wart that can charge the laptop quickly?
Alternatively can a USB-A wall wart of reasonable power used in connection with this https://store.pine64.org/?product=2-mete...ower-cable be used? If yes, then what wall warts are others using with this cable? This cable is listed under the laptops section of the store page and it's noted it works for "Pinebook" but I don't want to assume this matches the PBP as there are a hand full of other exceptions I've seen mentioned. If this does match with the PBP perhaps this could be more explicit on the store page.
Thanks for any help or insight anyone can provide!
This one works fine for me: https://youtu.be/4RKp-1nN6d8
Longer Power Cable - by Tekchip - 11-10-2019, 09:51 AM
RE: Longer Power Cable - by zaius - 11-10-2019, 11:41 AM
RE: Longer Power Cable - by xalius - 11-10-2019, 12:22 PM
RE: Longer Power Cable - by bcnaz - 11-10-2019, 12:33 PM
RE: Longer Power Cable - by pege - 11-10-2019, 02:11 PM
  Pinebook Pro on Debian 12 Power Issue u974615 1 339 03-13-2024, 10:46 AM
Last Post: u974615
  Pinebook Pro Source for Trackpad Flex / Ribbon Cable rankharris 1 282 02-17-2024, 07:06 PM
  Increasing the maximum power draw dsimic 15 19,637 11-21-2022, 03:36 AM
Last Post: bircoph
  Alternative Power supply options gallomimia 13 17,948 11-13-2022, 06:10 PM
Last Post: pineymousepad
  PBP booting but stops at flashing power led jonasd 13 5,493 09-26-2022, 12:17 AM
Last Post: jonasd
  Blinking red light for charger, no power-on bifo 11 13,801 11-30-2021, 01:37 PM
  power on PBP if your keyboard is dead? stozi 0 1,334 11-29-2021, 01:55 PM
Last Post: stozi
  Stiff hinges or a lid that no longer shuts dsimic 3 3,541 10-05-2021, 12:10 PM
Last Post: ab1jx
  Motherboard malfunction - a possible warning about power supplies mjc 8 7,108 07-28-2021, 01:04 PM
Last Post: mjc
  Some Keys No Longer Working pietenpol 0 1,752 06-05-2021, 05:39 PM
Last Post: pietenpol
