What do you want to see on a PBP skin?
Abstract designs
16.36%
9
Just the logo
21.82%
12
Simple repeating patterns
20.00%
11
Something with the Pine and OS logos
30.91%
17
Textures or photography
7.27%
4
Humor
3.64%
2
55 vote(s)
Skins for the community
#26
(11-10-2019, 10:13 AM)tophneal Wrote:
(11-10-2019, 10:07 AM)Tekchip Wrote: I've recently had my PBP apart. I hadn't updated uboot to boot SD without the hardware switch thrown and I borked the eMMC install. oops. That's not my point. My point is I noticed the PBP processor is using a heat transfer pad to transfer heat to the bottom panel. So the bottom panel appears to be an active part of the cooling system. We'd probably want someone from Pine to let us know if we're putting our hardware at risk of heat issues if we're adding an extra layer over the bottom panel.
If the answer is "that would be bad" maybe there's a way to design a skin with a cut out that allows the heat out but maintains the design. Maybe the pine cone part of the logo is offset to match where the heat transfer pad contacts leaving some black metal exposed to dissipate heat but that's also part of the lower skins design.
If I'm not explaining clearly please let me know and I can draw some pictures or something.
That makes sense. That could also cause a problem with the skin vinyl, too. Cheaper, or lighter duty vinyls don't always have any kind of heat resistance and can discolor, lose adhesion, and/or warp when exposed to excessive heat. Certain outdoor vinyls would probably still fair pretty well, though, since they are manufactured to handle elemental conditions that include heat, for a minimum number of years.
I think that since there are no fans we need to worry about blocking ventilation, we may be able to determine this ourselves, but measuring the bottom case temperatures while under load, and compare that to the specs of different vinyl options for skinning.
I think before we go hard at trying to measure temps and test ourselves we could just get a quick reply from someone at Pine. It's pretty clear since they engineered this solution that they have some knowledge of the heat produced such that they came up with this. I would expect they know what margin of heat headroom they're playing with on the processor.
Knowing this I for one will forgo any underside skinning as I tend to do anyway. Nearly 20 years in IT I've seen more than a few laptops die a heat death due to user's leaving packaging on(as if it's a skin). (so. many. dead. Dells.)
Skins for the community - by tophneal - 11-06-2019, 09:20 AM
RE: Skins for the community - by MrTester - 11-06-2019, 09:33 AM
Skins for the community - by tophneal - 11-06-2019, 09:40 AM
RE: Skins for the community - by MrTester - 11-06-2019, 10:17 AM
RE: Skins for the community - by Tekchip - 11-06-2019, 09:43 AM
RE: Skins for the community - by tophneal - 11-06-2019, 09:48 AM
RE: Skins for the community - by tophneal - 11-06-2019, 10:20 AM
RE: Skins for the community - by tophneal - 11-06-2019, 10:25 AM
RE: Skins for the community - by Schtromar - 11-06-2019, 04:20 PM
RE: Skins for the community - by tophneal - 11-06-2019, 04:41 PM
Skins for the community - by jabo - 11-07-2019, 09:48 AM
RE: Skins for the community - by tophneal - 11-07-2019, 10:00 AM
RE: Skins for the community - by jabo - 11-07-2019, 10:07 AM
RE: Skins for the community - by tophneal - 11-07-2019, 02:19 PM
RE: Skins for the community - by PakoSt - 11-07-2019, 06:35 PM
RE: Skins for the community - by VoxUnius - 11-07-2019, 08:17 PM
Skins for the community - by tophneal - 11-07-2019, 09:05 PM
RE: Skins for the community - by PakoSt - 11-08-2019, 06:11 AM
Skins for the community - by tophneal - 11-08-2019, 06:12 AM
RE: Skins for the community - by cristobalhdez - 11-08-2019, 09:23 AM
Skins for the community - by tophneal - 11-08-2019, 09:26 AM
RE: Skins for the community - by Luke - 11-08-2019, 10:04 AM
RE: Skins for the community - by Tekchip - 11-10-2019, 10:07 AM
RE: Skins for the community - by tophneal - 11-10-2019, 10:13 AM
RE: Skins for the community - by Tekchip - 11-10-2019, 10:32 AM
RE: Skins for the community - by Luke - 11-11-2019, 09:40 AM
RE: Skins for the community - by bcnaz - 11-11-2019, 11:31 AM
RE: Skins for the community - by bcnaz - 11-10-2019, 11:28 AM
Skins for the community - by tophneal - 11-10-2019, 12:04 PM
RE: Skins for the community - by PakoSt - 11-11-2019, 07:37 AM
RE: Skins for the community - by Unorthodactyl - 11-25-2019, 03:43 PM
RE: Skins for the community - by Luke - 11-25-2019, 05:57 PM
RE: Skins for the community - by tophneal - 11-26-2019, 07:32 AM
RE: Skins for the community - by Luke - 11-27-2019, 11:11 AM
RE: Skins for the community - by tophneal - 12-01-2019, 03:36 PM
RE: Skins for the community - by Luke - 12-01-2019, 05:16 PM
Skins for the community - by tophneal - 12-01-2019, 05:18 PM
RE: Skins for the community - by tophneal - 12-02-2019, 11:26 AM
RE: Skins for the community - by undo - 12-05-2019, 07:38 AM
RE: Skins for the community - by tophneal - 12-05-2019, 07:41 AM
RE: Skins for the community - by undo - 12-05-2019, 07:57 AM
RE: Skins for the community - by tophneal - 12-04-2019, 08:36 AM
RE: Skins for the community - by Luke - 12-05-2019, 11:38 AM
RE: Skins for the community - by tophneal - 12-05-2019, 11:45 AM
RE: Skins for the community - by Luke - 12-05-2019, 05:23 PM
Skins for the community - by tophneal - 12-05-2019, 05:25 PM
RE: Skins for the community - by PineFan - 12-06-2019, 09:37 PM
Skins for the community - by jabo - 12-06-2019, 09:36 AM
Skins for the community - by tophneal - 12-06-2019, 09:41 AM
Skins for the community - by jabo - 12-06-2019, 09:44 AM
Skins for the community - by tophneal - 12-06-2019, 09:46 AM
RE: Skins for the community - by tophneal - 12-06-2019, 03:27 PM
RE: Skins for the community - by clover - 12-06-2019, 04:54 PM
Skins for the community - by tophneal - 12-06-2019, 05:01 PM
RE: Skins for the community - by Luke - 12-06-2019, 08:36 PM
Skins for the community - by tophneal - 12-06-2019, 08:43 PM
RE: Skins for the community - by undo - 12-07-2019, 08:16 AM
Skins for the community - by tophneal - 12-07-2019, 08:18 AM
RE: Skins for the community - by undo - 12-07-2019, 08:27 AM
Skins for the community - by tophneal - 12-07-2019, 08:29 AM
RE: Skins for the community - by undo - 12-07-2019, 08:37 AM
Skins for the community - by tophneal - 12-07-2019, 08:39 AM
RE: Skins for the community - by undo - 12-07-2019, 08:57 AM
Skins for the community - by tophneal - 12-07-2019, 08:58 AM
RE: Skins for the community - by Luke - 12-07-2019, 09:21 AM
RE: Skins for the community - by undo - 12-07-2019, 10:25 AM
Skins for the community - by tophneal - 12-07-2019, 10:30 AM
RE: Skins for the community - by Tekchip - 12-07-2019, 12:18 PM
Skins for the community - by tophneal - 12-07-2019, 12:35 PM
RE: Skins for the community - by tophneal - 12-11-2019, 11:29 AM
RE: Skins for the community - by undo - 12-12-2019, 04:47 AM
RE: Skins for the community - by tophneal - 12-12-2019, 01:59 PM
RE: Skins for the community - by tophneal - 12-18-2019, 05:45 PM
RE: Skins for the community - by undo - 12-19-2019, 06:31 AM
RE: Skins for the community - by tophneal - 12-19-2019, 07:22 AM
RE: Skins for the community - by Luke - 12-19-2019, 04:05 AM
RE: Skins for the community - by krishorne5 - 01-17-2020, 03:05 PM
RE: Skins for the community - by tophneal - 01-17-2020, 03:12 PM
RE: Skins for the community - by Luke - 01-17-2020, 04:03 PM
RE: Skins for the community - by tophneal - 01-17-2020, 04:34 PM
RE: Skins for the community - by PakoSt - 01-17-2020, 05:21 PM
RE: Skins for the community - by tophneal - 01-17-2020, 11:28 PM
RE: Skins for the community - by tophneal - 01-21-2020, 11:02 AM
RE: Skins for the community - by LinuxIsNewToMe - 01-21-2020, 12:14 PM
RE: Skins for the community - by tophneal - 01-22-2020, 01:38 PM
RE: Skins for the community - by as400 - 01-23-2020, 05:00 AM
RE: Skins for the community - by tophneal - 01-23-2020, 07:06 AM
RE: Skins for the community - by as400 - 01-23-2020, 07:29 AM
RE: Skins for the community - by tophneal - 01-23-2020, 07:30 AM
RE: Skins for the community - by as400 - 01-23-2020, 07:34 AM
RE: Skins for the community - by tophneal - 01-23-2020, 08:00 AM
RE: Skins for the community - by cochra.Logica - 01-22-2020, 06:51 PM
RE: Skins for the community - by tophneal - 01-23-2020, 02:32 PM
RE: Skins for the community - by Bushrod - 01-25-2020, 03:28 AM
RE: Skins for the community - by tophneal - 01-25-2020, 07:11 AM
RE: Skins for the community - by Bushrod - 01-26-2020, 02:01 AM
RE: Skins for the community - by mamboman777 - 01-26-2020, 02:10 AM
Skins for the community - by tophneal - 01-26-2020, 09:55 AM
RE: Skins for the community - by gordie - 01-28-2020, 01:58 PM
RE: Skins for the community - by tophneal - 01-28-2020, 02:39 PM
RE: Skins for the community - by tophneal - 02-17-2020, 03:20 PM
RE: Skins for the community - by ColoBill - 02-22-2020, 03:45 PM
RE: Skins for the community - by tophneal - 02-23-2020, 07:05 PM
RE: Skins for the community - by Braillynn - 02-18-2021, 02:24 PM
RE: Skins for the community - by tophneal - 02-18-2021, 02:30 PM
RE: Skins for the community - by Braillynn - 02-19-2021, 03:38 PM
Skins for the community - by tophneal - 02-20-2021, 07:50 AM
RE: Skins for the community - by Braillynn - 02-20-2021, 01:18 PM
Skins for the community - by tophneal - 02-20-2021, 01:30 PM
RE: Skins for the community - by Lyrixcaz - 03-10-2021, 09:54 AM
Rainbow Community Wallpapers tophneal 15 15,014 06-09-2020, 09:54 PM
Last Post: SpoofyKid
  Just a thank you of creating a community device that makes HW fun again gabeeg 1 3,036 11-19-2019, 01:09 PM
  Pinebook Pro Community pre-order ending / public pre-order open on 25th Luke 8 13,224 08-26-2019, 09:31 PM
Last Post: mjsabby
