reboot / crash
#39
Really hard to tell @xmixahlx - the syslog is heavily bloated (!!) though I could search through if I knew specifically what to look for. Unfortunately looking at the log also points to the fact that my system locale was set incorrectly and therefore the log timestamps are invalid. I have fixed my system time and should it happen again, it'll be much easier to find the correct spot in the log.
In the meantime, I tried something: as I mentioned, I had it hard reboot 3 times, the most recent 2 were when running the WiDivine update. So, this final time, I set the CPU frequency to 1.01 GHz static set, to prevent the CPU frequency from changing on the fly as is the default. Having set the CPU frequency, the WiDevine upgrade completed successfully, and the PBP remained stable after the update had completed, with no hard reboot.
I can't confirm in my initial tests that this was the cause & solution, but I know that 2x in a row, the upgrade caused the PBP to reboot, then, having set the CPU frequency manually to a static value, the same update completed without issue. So it could be related.
I will continue to monitor things. Fingers crossed that's all it is, as I'm happy to turn off CPU frequency scaling...
Robbie Ferguson // Bald Nerd
NEMS Linux: https://nemslinux.com/ | My TV Show: https://category5.tv/ | My Blog: https://baldnerd.com
reboot / crash - by Der Geist der Maschine - 11-03-2019, 09:42 PM
RE: reboot / crash - by sinistermrcream - 11-05-2019, 09:56 AM
RE: reboot / crash - by dawncold - 11-06-2019, 05:39 PM
RE: reboot / crash - by Nappael - 11-06-2019, 06:02 PM
RE: reboot / crash - by Der Geist der Maschine - 11-06-2019, 11:53 PM
RE: reboot / crash - by Der Geist der Maschine - 11-07-2019, 10:24 AM
RE: reboot / crash - by MoonDog - 11-07-2019, 03:40 PM
RE: reboot / crash - by Der Geist der Maschine - 11-07-2019, 09:29 PM
RE: reboot / crash - by lispy - 11-08-2019, 01:53 AM
RE: reboot / crash - by Der Geist der Maschine - 11-08-2019, 10:08 AM
RE: reboot / crash - by kiloparsec - 11-10-2019, 08:05 PM
RE: reboot / crash - by hmuller - 11-10-2019, 09:24 PM
RE: reboot / crash - by Der Geist der Maschine - 11-10-2019, 10:35 PM
RE: reboot / crash - by kiloparsec - 11-12-2019, 08:40 PM
RE: reboot / crash - by bcnaz - 11-12-2019, 08:56 PM
RE: reboot / crash - by kiloparsec - 11-13-2019, 07:08 PM
RE: reboot / crash - by Der Geist der Maschine - 11-16-2019, 08:34 PM
RE: reboot / crash - by Eggmonkey - 11-17-2019, 07:40 AM
RE: reboot / crash - by Der Geist der Maschine - 11-17-2019, 09:26 AM
RE: reboot / crash - by Arwen - 11-17-2019, 11:33 AM
RE: reboot / crash - by Eggmonkey - 11-17-2019, 03:55 PM
RE: reboot / crash - by bcnaz - 11-17-2019, 02:51 PM
RE: reboot / crash - by bcnaz - 11-17-2019, 04:22 PM
RE: reboot / crash - by Arwen - 11-18-2019, 05:24 AM
RE: reboot / crash - by Der Geist der Maschine - 11-19-2019, 08:23 PM
RE: reboot / crash - by GLSRacer - 11-24-2019, 10:34 AM
RE: reboot / crash - by Der Geist der Maschine - 11-24-2019, 10:51 AM
RE: reboot / crash - by james64 - 01-23-2020, 03:12 PM
RE: reboot / crash - by Der Geist der Maschine - 01-24-2020, 12:06 PM
RE: reboot / crash - by Twix166 - 01-01-2020, 02:08 PM
RE: reboot / crash - by Der Geist der Maschine - 01-01-2020, 04:25 PM
RE: reboot / crash - by Twix166 - 01-02-2020, 02:30 AM
RE: reboot / crash - by Der Geist der Maschine - 01-02-2020, 04:14 AM
RE: reboot / crash - by xmixahlx - 01-23-2020, 06:18 PM
RE: reboot / crash - by james64 - 01-24-2020, 11:35 AM
RE: reboot / crash - by xmixahlx - 01-24-2020, 01:34 PM
RE: reboot / crash - by Baldnerd - 01-27-2020, 10:27 AM
RE: reboot / crash - by xmixahlx - 01-27-2020, 01:37 PM
RE: reboot / crash - by Baldnerd - 01-27-2020, 02:00 PM
RE: reboot / crash - by james64 - 01-29-2020, 04:14 PM
RE: reboot / crash - by Baldnerd - 02-10-2020, 07:57 AM
  Video Flashing/adjusting on boot and reboot jbradley419 0 385 01-16-2024, 09:17 AM
Last Post: jbradley419
  Vertical Grey Bars on PBP Reboot MickTheGeek 5 4,971 06-04-2021, 02:43 AM
Last Post: dsimic
  Gimp makes stock Manjaro KDE/X11 crash stozi 3 4,391 04-21-2021, 08:15 AM
Last Post: stozi
  Keyboard settings not saved on reboot motezart 6 7,509 11-26-2020, 12:11 PM
Last Post: creaverse
  Vertical Grey Bars on PBP Reboot MickTheGeek 2 3,417 10-05-2020, 07:29 AM
Last Post: MickTheGeek
  Connection to specific AP fails after first reboot. DroneOn 2 3,372 07-13-2020, 06:15 PM
Last Post: DroneOn
  vertical bars reboot only mamboman777 2 3,754 07-09-2020, 12:51 PM
Last Post: mamboman777
Bug How about a hard power switch? + crash report Dendrocalamus64 7 9,759 05-24-2020, 04:03 PM
  Pinebook pro random reboot default Debian tso4ev 3 4,814 02-04-2020, 06:30 PM
Last Post: Baldnerd
  Blank Screen after reboot Sats 12 12,753 01-27-2020, 02:23 PM
Last Post: Sats
