Use Audiojack instead of HDMI audio
#44
(08-01-2016, 08:34 PM)apple4ever Wrote: I too cannot get headphones to work. I know the actual port works, because I loaded up a test Android image to confirm that.
I have the two files in the right place. I have all the software installed. I have audiocodec showing. I have audiocodec selected. I have the volume turned up.
Yet no sounds at all. Help!?! What else can I try? This is really annoying.
Thanks.
Can you give a little more info? Which version of linux are your using - ubuntu or debian? Is the kernel up-to-date - I believe  3.10.102-2 is the latest (run 'uname -a' to find out what version you're running). As long as you're running a version of linux based on pine64-longsleep's kernel, you can run the following commands when logged in as root (su) to ensure your uboot and kernel are up to date.
pine64_update_uboot.sh
pine64_update_kernel.sh
Also, how are you trying the play some sound?
Use Audiojack instead of HDMI audio - by pictus - 04-27-2016, 12:45 PM
RE: Use Audiojack instead of HDMI audio - by Luke - 04-29-2016, 07:13 PM
RE: Use Audiojack instead of HDMI audio - by pfeerick - 08-02-2016, 03:01 AM
lenny, help with audio jack - by rahlquist - 04-28-2016, 11:35 AM
RE: lenny, help with audio jack - by baryluk - 04-28-2016, 04:21 PM
RE: lenny, help with audio jack - by rahlquist - 04-28-2016, 09:27 PM
RE: lenny, help with audio jack - by tllim - 04-28-2016, 04:41 PM
  +LTS/SOPINE Audio Jack Pinout Little_Johnny 0 3,059 12-29-2019, 08:44 AM
Last Post: Little_Johnny
  Pine64 (analog) Audio Jack Output w/ Kernel 4.19 ecolezen 0 3,148 01-24-2019, 07:00 AM
Last Post: ecolezen
  PINE64 STEREO AUDIO DAC POT jtgiroux 0 3,230 01-12-2019, 04:56 PM
Last Post: jtgiroux
  Sound quality from audio jack devanl 0 3,338 10-11-2017, 10:39 PM
Last Post: devanl
  Audio Extractor Ralck 1 4,569 05-25-2017, 12:25 PM
Last Post: dkryder
  Using the pine64 with AVR - HDMI pass-through Moshe.Vazan 4 6,278 01-02-2017, 02:58 PM
Last Post: Moshe.Vazan
  HDMI touch screen not detected Radio 2 4,678 09-29-2016, 06:42 AM
Last Post: Luke
