SPDIF to TOSLINK
The characteristics of the devices on the reference page I presented above are all identical (except Obsolete) and are as follows.
The only difference is the package outline.
And all of the above devices operate with a power supply in the range of 2.7V to 5.5V.
Therefore, the "PLT133/T8" you have selected should also work with a 3.3V power supply.
--- Quoted from Data Sheet ---
Features
・ High speed signal transmission 16Mbps NRZ Signal.
・ TTL interface compatible.
・ +3V ~ +5V single power source.
Recommended Operating Conditions
Supply Voltage Vcc: 2.7 (MIN) 3.0 (TYP) 5.50 (MAX) (V)
SPDIF to TOSLINK - by zener - 10-02-2019, 05:41 AM
RE: SPDIF to TOSLINK - by Nikolay_Po - 10-16-2019, 01:18 AM
RE: SPDIF to TOSLINK - by ChriChri - 02-19-2020, 06:02 AM
RE: SPDIF to TOSLINK - by ChriChri - 03-05-2020, 10:57 PM
RE: SPDIF to TOSLINK - by Nikolay_Po - 03-09-2020, 12:59 PM
RE: SPDIF to TOSLINK - by ChriChri - 03-10-2020, 02:16 AM
RE: SPDIF to TOSLINK - by t4_4t - 03-06-2020, 07:46 AM
RE: SPDIF to TOSLINK - by ChriChri - 03-07-2020, 02:40 AM
RE: SPDIF to TOSLINK - by t4_4t - 03-10-2020, 04:20 AM
RE: SPDIF to TOSLINK - by ChriChri - 03-12-2020, 04:21 PM
RE: SPDIF to TOSLINK - by Nikolay_Po - 03-15-2020, 05:53 AM
RE: SPDIF to TOSLINK - by ChriChri - 04-04-2020, 11:24 AM
RE: SPDIF to TOSLINK - by ChriChri - 04-08-2020, 07:17 AM
  connector type SPDIF FAN RTC battery? ChriChri 4 5,771 03-21-2020, 06:47 AM
Last Post: ChriChri
  SPDIF optical cable? zener 1 2,818 12-24-2018, 09:52 PM
