[26/09/2019] /e/ on pinebook, lineage derivative
I work with /e/ and over the last months I've been working on porting the pinebook to /e/
I'm publishing a first really early version of the OS you can try on your pinebook.
Download
https://ecloud.global/s/W67mXRYxmfBxL2i
Archive:
12-09-2019 https://ecloud.global/s/PPcRrgxYdd2trso
Source repository:
https://gitlab.e.foundation/a64/
This was tested on a pinebook 1080p
As for ayufan build, you can change it to batch 1 or 2, and you can try it on other devices
Please tell me which issues you encounter
one that I already know are screen flickering on the pinebook 1080p
you can "fix" it (not a real fix) by enabling the "disable HW layer" in dev options
also
Camera has bad colors
Installation guide
With a linux computer
Extract the gz archive
insert a microsd of at least 8gB
then
sudo fdisk -l
Try to find your micro sd
should be something like /dev/sdX
be sure you've found the right device, next step will remove everything on it
then
sudo dd if=extacted-file-path of=/dev/sdX
replace X wil the letter you've found in previous step
[26/09/2019] /e/ on pinebook, lineage derivative - by Phie - 09-12-2019, 07:05 AM
RE: /e/ on pinebook, lineage derivative - by Luke - 09-12-2019, 07:43 AM
RE: /e/ on pinebook, lineage derivative - by Phie - 09-13-2019, 12:46 AM
RE: /e/ on pinebook, lineage derivative - by Luke - 09-13-2019, 07:32 AM
RE: /e/ on pinebook, lineage derivative - by Phie - 09-18-2019, 06:37 AM
Smile PrimeOS for Pinebook 1080p teamprimeos 0 2,328 11-08-2021, 08:37 AM
Last Post: teamprimeos
  Lineage + pinebook, havin an issue when porting it Phie 5 8,761 01-18-2021, 09:02 AM
Last Post: mindao
  Privacy of Android and Chromium on new PineBook Clea 3 6,162 10-15-2019, 09:19 AM
  Android for 1080p Pinebook? Tomash 7 10,769 09-09-2019, 07:30 AM
  Bliss OS for Pinebook tllim 61 90,448 07-08-2019, 06:34 PM
  Stock Android for 1080P Pinebook pineadmin 1 5,565 11-24-2018, 09:45 AM
Last Post: ramboton
  Android 7.1 (Pinebook) pineadmin 50 75,216 05-30-2018, 03:13 PM
Last Post: Wizzard
  Android 6.0.1 (Pinebook) 20170605 pineadmin 6 12,697 12-30-2017, 06:55 AM
Last Post: milkaca
  Android 7.1 (Pinebook) v0.3.3-r59 pineadmin 3 7,913 05-09-2017, 04:59 AM
Last Post: Luke
  Pre-release android 7.1 for Pinebook Luke 0 5,217 04-22-2017, 10:58 AM
Last Post: Luke
