Network problems (actually bad power supply)
(11-26-2019, 12:48 PM)ykanello Wrote: I am having network timeouts towards all SoC of the clusterboard.
I have never noticed this. However, due to the other issues the board doesn't see much network traffic. I would suggest checking bandwidth utilization and pinging between the modules. They only have 100Mbit interfaces and saturation causes packet loss.
(11-26-2019, 12:48 PM)ykanello Wrote: After reading the posts with regards to the PSU, I removed two SoC and now is running with 5, but the problem still persists.
My problem SoC produce these errors within dmesg. Check if any show it. You may also want to try using an ATX power supply.
[15507.597377] rcu: rcu_sched kthread starved for 15755 jiffies! g1064201 f0x0 RCU_GP_WAIT_FQS(5) ->state=0x402 ->cpu=0
[15507.597380] rcu: RCU grace-period kthread stack dump:
[15507.597384] rcu_sched       I    0    10      2 0x00000028
(11-26-2019, 12:48 PM)ykanello Wrote: I do not have the time drift problem (date set to a far future) anymore after I installed the recommended kernel package from the community. [linux-image-next-sunxi64_5.99_arm64.deb]
I recently moved to linux-image-current-sunxi64_5.3.9 and the time jumps have ceased. However, now the Ethernet device will shut off.
(11-26-2019, 12:48 PM)ykanello Wrote: I rely heavily on the network of the clusterboard and this timeout issue makes the clusterboard quite useless for me.
Does any one have a solid idea on what the problem could be?
Not that my research has showed. You could try adding some fans to the case and heatsinks to cool chips. Additional, cooling and an ATX power supply are on my todo list. The clusterboard chips show around 90F when ambient is around 60F.
RE: Network problems - by Dreamwalker - 09-11-2019, 10:31 AM
RE: Network problems - by Unkn0wn - 09-11-2019, 12:45 PM
RE: Network problems - by Unkn0wn - 09-27-2019, 04:07 AM
RE: Network problems - by Dreamwalker - 09-17-2019, 10:38 AM
RE: Network problems - by Unkn0wn - 09-17-2019, 03:50 PM
RE: Network problems (actually bad power supply) - by venix1 - 12-01-2019, 10:02 AM
Sad Version/Date of last armbian build that came with network patches? Bazmundi 0 272 12-07-2023, 03:23 PM
Last Post: Bazmundi
  Creating a current armbian-Image with network-fix clusterDude 14 24,329 12-12-2022, 01:30 AM
Last Post: langerma
  Clusterboard not getting IP address after network fix Norlark 14 12,802 08-30-2021, 05:00 PM
Last Post: poVoq
  ArchLinux Network Booting xblack86 2 3,925 02-25-2021, 08:42 AM
Last Post: xblack86
  sopine socket power problem cgiraldo 1 3,335 06-17-2020, 02:10 PM
Last Post: cgiraldo
  Clusterboard networking problems BryanS 25 30,403 03-31-2019, 04:06 PM
Last Post: aww
  Power Switch AZClusterboard 1 2,870 02-16-2019, 06:55 AM
Last Post: mdmbc
  Individual SOPINE Power On After Shutdown? Pine 2 3,887 01-30-2019, 08:04 AM
Last Post: mdmbc
  Question on the power resistors bergera 2 4,121 02-15-2018, 08:20 AM
Last Post: bergera
