NixOS image with panfrost
I've recently installed NixOS on my RockPro64, and since I've got the panfrost driver working, I thought I'd create a bootable image so that people can give it a try with minimal effort. Simply download and extract the image here and write it to an sd-card or eMMC using your favourite disk image writing tool (The image is 4.7GB, so you'll probably need an 8GB or larger SD card/eMMC). It should boot and automatically log into the KDE plasma desktop. (user is called rockpro64, password rockpro64). It uses the 5.3 ayufan-rock64/linux-mainline-kernel. It takes a minute or two to boot, so you may wish to follow its progress via the UART if you can.
This image can be used as an installer: simply follow the instructions in the NixOS wiki to create /etc/nixos/configuration.nix and run nixos-rebuild. If you'd prefer to build your own image, RockPro64-specific information can be found here.
Note: Normally, NixOS fetches most packages from a binary cache. However, since this image uses a different version of mesa, anything which depends on mesa (basically any graphical application) will be built from source.
NixOS image with panfrost - by Thra11 - 08-31-2019, 05:06 AM
RE: NixOS image with panfrost - by tuxd3v - 08-31-2019, 11:09 AM
RE: NixOS image with panfrost - by kolbycrouch - 09-24-2019, 12:07 PM
RE: NixOS image with panfrost - by Thra11 - 09-27-2019, 08:05 AM
RE: NixOS image with panfrost - by kolbycrouch - 11-03-2019, 01:13 AM
  Debian image configured for USB-C OTG? djonathan 2 2,606 01-06-2022, 03:09 AM
Last Post: susy1075
  First Lakka image for ROCKPro64 Ntemis 12 20,823 09-18-2020, 01:50 AM
Last Post: Wizzard
  Rockpro64 panfrost installation questions user12321 2 4,582 05-27-2020, 10:17 AM
Last Post: xmixahlx
  RPro Image Suggestions jl_678 4 5,375 04-16-2020, 09:06 AM
Last Post: jl_678
  Recalbox Image is available Luke 0 2,061 03-06-2020, 05:28 PM
Last Post: Luke
  Anyone tried the new mainline images (Panfrost)? stuartiannaylor 0 2,416 08-13-2019, 07:04 AM
Last Post: stuartiannaylor
  computelibrary build issue with latest ubuntu 18 image rahulsharma 0 1,724 07-08-2019, 09:25 AM
Last Post: rahulsharma
Question freeze on multiple image from wiki Slam 6 7,057 05-12-2019, 04:08 PM
Last Post: Slam
  Image for ZFS on PCIe SATA drives with OpenVPN and WiFi caillou 0 1,890 02-26-2019, 05:14 PM
Last Post: caillou
  debian image rocksa 2 3,762 02-08-2019, 09:53 AM
Last Post: rocksa
