[WIP] backup server (4 sata HDDs + ZFS)
Sad
(08-18-2019, 04:39 PM)rolando Wrote: Hey everyone! I'm in the process of building a replacement (home) backup server for an old rpi3 I had around: it was running arch + (native) encrypted ZFS. Disks were connected through a USB hard-drive bay. It worked, but it was clumsy and slow.
When I learned about the rockpro64, I figured that would work great for a replacement of that server.
Here are the specs:
- RockPro64 4GB
- 2x1Tb HDD WD Blue (will upgrade to 4x2Tb if this works well)
- Qnine 4 port SATA PCIe card
- Norco ITX-S4 Black mini-ITX case
- Solid Gear FLEX 320W power supply
- Debian stretch (last version available on ayufan's github)
Bonjour ...
Vous avez de la chance car ma carte PCIe SATA 4 Ports fait planter le système Debian Buster avec des « timeout » et finir avec un « kernel panic »  Sad
Hello ...
You are lucky because my 4 Ports SATA PCIe Card crashes the Debian Buster system with « timeouts » and ends with a « kernel panic »  Sad
[Image: IHDuOabve45_20190829-223306-1.jpg]
RE: [WIP] backup server (4 sata HDDs + ZFS) - by dml-pc - 08-29-2019, 02:41 PM
  Smart TV & server storz 1 1,357 01-19-2024, 01:59 PM
Last Post: dairymilkbatman
  Home Server with RAID 1 SATA M2 SSDs runyor 7 2,540 09-26-2023, 09:14 AM
  Umbrel Server Shaeroden 0 1,355 05-04-2022, 06:14 PM
Last Post: Shaeroden
  SkiffOS server with Docker ,NAS, Home assistant, Jellyfin, Snikket XMPP (tutorial) GreyLinux 12 10,085 04-04-2022, 05:26 AM
Last Post: GreyLinux
  SimpNas server with docker - home assistant, radicale , jellyfin & esphome (tutorial) GreyLinux 0 4,414 01-17-2021, 11:33 AM
  OMV + VPN server + Pi Hole? odhinnhrafn 3 7,955 03-16-2020, 05:01 PM
Last Post: mabs
  RockPro64 as PATA/SATA bridge? Count Omega 1 4,313 12-07-2019, 02:25 PM
Last Post: Count Omega
Video ARMBand an easily configured Home Media Server gabrielsr 2 6,198 07-22-2019, 04:56 AM
Last Post: stuartiannaylor
