Penbook - Kali ARM64 BETA RELEASE
(11-26-2019, 05:35 PM)Athlex Wrote:
(11-12-2019, 08:40 PM)cephasiii Wrote:
(10-20-2019, 12:47 PM)rookieone Wrote: Here's a Kali Pinebook download:
https://www.offensive-security.com/kali-...f090d-c5ea
Not sure if this is for emmc or sdcard?
Has anyone been able to get the offensive security Kali arm to run on pinebook? If so, what are the steps? I haven’t had any success loading on SD via etcher and booting.
TIA
Version 2019.4 was released yesterday or today and it seems to work great on my 11" Pinebook 1080P using a microSD card.  I haven't tried to install it to the eMMC.  If you're on a Windows box, this works.  If you're starting with Linux/macos, you'd use `dd` in place of steps 3 and 4.  (I haven't used Etcher)
1.  Grab https://images.offensive-security.com/ar...ook.img.xz
2.  Extract the img file using a tool like 7-Zip
3.  Nuke whatever filesystem you have on the flash disk with `diskpart`
4.  Write the image to a flash card with a tool like `physdiskwrite` (https://m0n0.ch/wall/physdiskwrite.php - there are lots of other options, I use this out of habit)  The amount of data it reports writing is probably wrong, don't worry about it.  You'll be dropped at the command prompt when it finishes, ~10 minutes.
5.  Stick it in your Pinebook and power it on and it should boot up to an xfce login screen.  Be patient, it's slow.
6.  Login with root/toor and run `apt update && apt upgrade`
7.  For connectivity, it'll work with USB ethernet adapters out of the box.  If you want to use the built-in wireless, go to /usr/src/rtl8723cs and run `dkms install .`
8.  I also found the default backlight brightness to be really dim, so you can also run `pkexec --user root xfpm-power-backlight-helper --set-brightness 10`
9.  Load tools - the install is very minimal and while it has a GUI, it doesn't include essentials like tmux or net-tools
10.  Hack the planet.
Thanks! do you have a changelog for it?
Penbook - Kali ARM64 BETA RELEASE - by mhedhli - 08-15-2019, 11:53 AM
RE: Penbook - Kali ARM64 BETA RELEASE - by letarg - 09-08-2019, 08:20 AM
RE: Penbook - Kali ARM64 BETA RELEASE - by Athlex - 11-26-2019, 05:35 PM
RE: Penbook - Kali ARM64 BETA RELEASE - by Luke - 11-26-2019, 05:37 PM
RE: Penbook - Kali ARM64 BETA RELEASE - by Athlex - 11-26-2019, 06:03 PM
Penbook - Kali ARM64 BETA RELEASE - by e-minguez - 01-28-2020, 02:48 PM
  Armbian 22.02 Release Announcement TRS-80 0 1,375 02-28-2022, 05:02 PM
Last Post: TRS-80
  E: The repository 'http://pinebook.kde.org.uk bionic Release' no longer has a Release pixelpaperyarn 3 5,300 05-07-2021, 10:20 AM
  pinebook.kde.org.uk no longer has release file?? supermassive 1 3,849 01-20-2021, 11:18 AM
  Kali on SD does not Detect EMMC marianobilli 1 3,348 01-07-2021, 06:56 PM
Last Post: evilbunny
  Kali Linux for the Pinebook Luke 1 4,895 03-03-2020, 05:01 AM
Last Post: e-minguez
Smile Ubuntu Release Upgrade (16.04 => 16.10 => 17.04) working stohn 19 22,529 10-21-2018, 03:34 AM
Last Post: soupbowl
  New pre-release Ubuntu img Luke 6 7,122 07-10-2017, 02:39 AM
Last Post: dkryder
