Power Consumption
(07-23-2019, 01:59 PM)fire219 Wrote: I don't think proper tests of power consumption have been done, however some educated guesses could be made.
The RK3399 pulls about 6 watts at max load. When idle, it will pull a small fraction of that. With all the screen off, the power consumption of all the other components is negligible. Combined, it's probably no more than 6W, and likely a fair bit less if you have WiFi+BT disabled.
With the screen at full brightness, you're probably looking at 10 watts at most. I don't have the display panel datasheet on hand, but 4W is a reasonable (though a bit high) estimate based on other datasheets I do have.
Prob somewhere very close to the google OP1 powered rk3399 chromebooks as its practically the same thing.
Prob 350mAh-500
Power Consumption - by mala - 07-23-2019, 04:15 AM
RE: Power Consumption - by User 12559 - 07-23-2019, 01:04 PM
RE: Power Consumption - by fire219 - 07-23-2019, 01:59 PM
RE: Power Consumption - by stuartiannaylor - 07-23-2019, 02:13 PM
RE: Power Consumption - by User 12559 - 07-23-2019, 02:43 PM
RE: Power Consumption - by stuartiannaylor - 07-23-2019, 04:48 PM
RE: Power Consumption - by User 12559 - 07-23-2019, 05:59 PM
RE: Power Consumption - by stuartiannaylor - 07-24-2019, 08:50 AM
RE: Power Consumption - by User 12559 - 07-24-2019, 09:20 AM
RE: Power Consumption - by stuartiannaylor - 07-24-2019, 10:16 AM
RE: Power Consumption - by fire219 - 07-24-2019, 01:57 PM
RE: Power Consumption - by stuartiannaylor - 07-24-2019, 02:27 PM
RE: Power Consumption - by mala - 08-22-2019, 04:33 AM
RE: Power Consumption - Battery life? - by ab1jx - 10-11-2019, 04:12 PM
  Pinebook Pro on Debian 12 Power Issue u974615 1 379 03-13-2024, 10:46 AM
Last Post: u974615
  Increasing the maximum power draw dsimic 15 19,832 11-21-2022, 03:36 AM
Last Post: bircoph
  Alternative Power supply options gallomimia 13 18,129 11-13-2022, 06:10 PM
Last Post: pineymousepad
  PBP booting but stops at flashing power led jonasd 13 5,658 09-26-2022, 12:17 AM
Last Post: jonasd
  Blinking red light for charger, no power-on bifo 11 14,039 11-30-2021, 01:37 PM
  power on PBP if your keyboard is dead? stozi 0 1,353 11-29-2021, 01:55 PM
Last Post: stozi
  Motherboard malfunction - a possible warning about power supplies mjc 8 7,231 07-28-2021, 01:04 PM
Last Post: mjc
Question UK Power Supply User 11436 11 17,688 02-09-2021, 12:30 PM
Last Post: dieselnutjob
  Pinebook Pro Dock Power Requirements calinb 9 12,332 12-16-2020, 09:24 AM
Last Post: dsimic
  Auto-wake behavior when external power is connected diodelass 7 10,077 12-05-2020, 01:19 AM
Last Post: dsimic
